查看: 637|回复: 1
[求助]:如何得到两条曲线的交点
发表于 2005-6-9 12:52:06 | 显示全部楼层 |阅读模式
多谢!
发表于 2005-6-9 19:28:08 | 显示全部楼层
Signature
RetVal = object.IntersectWith(IntersectObject, ExtendOption)
Object
All Drawing Objects (Except Pviewport and PolygonMesh)
The object or objects this method applies to.
IntersectObject
Object, input-only;
The object can be one of All Drawing Objects.
ExtendOption
AcExtendOption enum; input-only
This option specifies if one or the other, both, or none of the entities are to be extended in order to attempt an intersection.
acExtendNone
Does not extend either object.
acExtendThisEntity
Extends the base object.
acExtendOtherEntity
Extends the object passed as an argument.
acExtendBoth
Extends both objects.
RetVal
Variant (array of doubles)
The array of points where one object intersects another object in the drawing
GMT+8, 2026-11-3 12:13 , Processed in 0.534384 second(s), 34 queries , Gzip On.
