查看: 831|回复: 5
[求助]:能不能把mdl中自己写的函数做成dll
发表于 2005-6-10 13:42:00 | 显示全部楼层 |阅读模式
需要给别人用 但是不能给代码
发表于 2005-6-10 18:42:48 | 显示全部楼层
最简单的方法是做成MDL的共享库*.ML给别人用。不需要涉及DLL。
 楼主| 发表于 2005-6-12 15:35:57 | 显示全部楼层
MDL的共享库*.ML怎么做 好像没有见到过呀
请ms迷详细讲讲
发表于 2005-6-13 07:46:52 | 显示全部楼层
仔细阅读MDL_Programmer_Guide的Using_the_MDL_Librarian 一节。最近忙于PDMS工作,没有时间给您翻译了(抱歉)。
 楼主| 发表于 2005-6-13 10:00:41 | 显示全部楼层
没有找到您说的 Using_the_MDL_Librarian 一节啊
发表于 2005-6-13 16:55:04 | 显示全部楼层
Using the MDL Librarian
The MDL librarian, mlib, is used to combine multiple MDL object (.mo) files into a larger, linkable, MDL library (.ml) file. Use of this utility is optional, and many MDL applications, including basic.ma, are built without using mlib.
The command line syntax for the MDL librarian is as follows:
MLIB COMMAND[MODIFIERS] LIBRARY-FILE [INPUT-FILES]
The commands are as follows:
command  description
a  Add the files to the library file.
d  Delete the files from the library file.
t  Display a table of contents.
x  Extract the files from the library.
The modifiers are:
modifier  description
v  Verbose.
c  Do not display a message if the library file is created.
The following command requests a verbose table of contents of the mathlib.m library file:
MLIB -TV MATHLIB.ML
mlib stores any type of file in a library file. If the file being stored is an MDL object file, mlib extracts information from the file's symbol table and stores the information in the library file's header. This activity enables mlink to process the library faster when deciding which object images from the library file should be used.
  Popup
GMT+8, 2026-11-22 11:05 , Processed in 0.394473 second(s), 20 queries , Gzip On, File On.
