查看: 1017|回复: 0
[ARX程序]:请帮我看一下,ObjectARX2005上的例子
发表于 2005-6-12 01:10:58 | 显示全部楼层 |阅读模式
我刚学ARX
按照Object2005上的例子为什么编译错误
这是第一个例子
ArxProject.def
LIBRARY        Step01
EXPORTS
        acrxEntryPoint          PRIVATE
        acrxGetApiVersion       PRIVATE
HelloWorld.cpp
#include "stdafx.h"
#include <aced.h>
#include <rxregsvc.h>
void initApp();
void unloadApp();
void helloWorld();
void initApp()
    // register a command with the AutoCAD command mechanism
    acedRegCmds->addCommand("HELLOWORLD_COMMANDS",
                            "Hello",
                            "Bonjour",
                            ACRX_CMD_TRANSPARENT,
                            helloWorld);
void unloadApp()
        acedRegCmds->removeGroup("HELLOWORLD_COMMANDS");
void helloWorld()
        acutPrintf("\nHello World!");
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* pkt)
    switch (msg)
        case AcRx::kInitAppMsg:
            acrxDynamicLinker->unlockApplication(pkt);
            acrxRegisterAppMDIAware(pkt);
            initApp();
            break;
        case AcRx::kUnloadAppMsg:
            unloadApp();
            break;
        default:
            break;
    return AcRx::kRetOK;
Step01.cpp
// Step01.cpp : Defines the entry point for the DLL application.
#include "stdafx.h"
BOOL APIENTRY DllMain( HANDLE hModule,
                       DWORD  ul_reason_for_call,
                       LPVOID lpReserved
    return TRUE;
stdafx.h
// stdafx.cpp : source file that includes just the standard includes
// Step01.pch will be the pre-compiled header
// stdafx.obj will contain the pre-compiled type information
#include "stdafx.h"
// TODO: reference any additional headers you need in STDAFX.H
// and not in this file
stdafx.h
// stdafx.h : include file for standard system include files,
// or project specific include files that are used frequently, but
// are changed infrequently
#pragma once
#define WIN32_LEAN_AND_MEAN                // Exclude rarely-used stuff from Windows headers
// Windows Header Files:
#include <windows.h>
// TODO: reference additional headers your program requires here
GMT+8, 2026-11-22 08:43 , Processed in 0.271788 second(s), 10 queries , Gzip On, File On.
