查看: 3331|回复: 4
[求助]:各位朋友新年好~,有空来帮小弟看一下这个关于AcEdJig的程序!谢谢!
发表于 2006-1-23 11:33:33 | 显示全部楼层 |阅读模式
这个程序主要实现的是实体关联拖动,但次程序是先要对实体进行3D渲染,我理解好象是一定要渲染后,才能调用Intermediary.h中的worlddraw()函数,但具体是怎么调用的我不太清楚。请各位朋友看一下,3D渲染和Intermediary.h是一个什么关系,我想不用3D渲染实现同样的功能,该如何修改?有劳各位朋友了!
//****Jig3dcmd.cpp****//
#include "stdafx.h"
#include "acdb.h"
#include "acgs.h"
#include "gs.h"
#include "acedads.h"
#include "acgsmanager.h"
#include "dbmain.h"
#include "acestext.h"
#include "acdocman.h"
#include "adscodes.h"
#include "dbsymtb.h"
#include "dbents.h"
#include "gemat3d.h"
#include "acgi.h"
#include "geassign.h"
#include <math.h>
#include "dbjig.h"
#include "cmdexception.h"
#include "intermediary.h"
#include "dbapserv.h"
#include "aced.h"
#include "dbxutil.h"
#if _MSC_VER > 1200
#pragma warning(push)
#endif
#pragma warning(disable:4290)
#pragma warning(disable:4310)
static AcDbObjectId GetModelSpaceBlockID (void)
    AcDbObjectId            ObjectId;
    AcDbBlockTable *        pBlockTable;
    Acad::ErrorStatus       status;
    status = acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBlockTable, AcDb::kForRead);
    if (status != Acad::eOk)
        return false;
    status = pBlockTable->getAt(ACDB_MODEL_SPACE, ObjectId);
    pBlockTable->close();
    return ObjectId;
class Jig3d : public AcEdJig
protected:
    AcDbPolyline m_dummy;
    AcGsModel* m_pModel;
    AcGePoint3d m_refPoint;
    double m_elev;
    Intermediary m_int;
        AcGeMatrix3d m_xform;
        AcGeMatrix3d m_xformTemp;
    AcGePoint3d  m_LastPoint;
    AcDbObjectId m_MSBObjectID;
        enum Mode {kMove=0, kRotateX, kRotateY, kRotateZ} m_mode;
        void apply() throw(CmdException);
public:
    Jig3d()
        :m_pModel(0),m_LastPoint(0.0,0.0,0.0)
    ~Jig3d();
        //This sample uses AcEdJig in a slightly unconventional way.
        //The following two overrides are usually concerned with
        //updating the display. They are dummies in this sample
        //since we are updating the display ourselves.
    virtual Adesk::Boolean  update()
            return Adesk::kFalse;
    virtual AcDbEntity* entity() const
            return const_cast<AcDbPolyline*>(&m_dummy);
        virtual DragStatus        sampler();
    void engage(void)throw(CmdException);
        void init(const AcDbObjectId& idEntity,const AcGePoint3d& refPoint,int viewportNumber) throw(CmdException);
Jig3d::~Jig3d()
    if (m_pModel)
        m_pModel->onErased (&m_int, m_MSBObjectID.asOldId());
AcEdJig::DragStatus Jig3d::sampler()
    setSpecialCursorType(AcEdJig::kRubberBand);   //&sup1;&acirc;±ê
    AcGePoint3d pt,temp;
        AcEdJig::DragStatus status;
        double angle;
        if (m_mode == kMove){
                setKeywordList("Base X Y Z Exit");    //&sup1;&Oslash;&frac14;ü×&Ouml;
                status = acquirePoint(pt,m_refPoint);
        acdbWcs2Ucs(asDblArray(pt),asDblArray(pt),Adesk::kFalse);
        pt.z = m_elev;
        acdbUcs2Wcs(asDblArray(pt),asDblArray(pt),Adesk::kFalse);
        } else {
                setKeywordList("Exit");
        pt.z = m_elev;
                angle = acutAngle(asDblArray(pt),asDblArray(m_refPoint));    //
    if (pt == m_LastPoint)      // if there is no work to be done,
        return status;          // exit early!
    m_LastPoint = pt;
        if (status == AcEdJig::kNormal){
                switch (m_mode)
                case kMove:
                        m_xformTemp = AcGeMatrix3d::translation(pt-m_refPoint);
                        m_int.setTransform(m_xformTemp*m_xform);
                        break;
                case kRotateX:
                        m_xformTemp = AcGeMatrix3d::rotation(angle,AcGeVector3d::kXAxis,m_refPoint);
                        break;
                case kRotateY:
                        m_xformTemp = AcGeMatrix3d::rotation(angle,AcGeVector3d::kYAxis,m_refPoint);
                        break;
                case kRotateZ:
                        m_xformTemp = AcGeMatrix3d::rotation(angle,AcGeVector3d::kZAxis,m_refPoint);
                        break;
                m_pModel->onModified(&m_int, m_MSBObjectID.asOldId());
    return status;
void Jig3d::apply() throw(CmdException)
        m_xform = m_xformTemp*m_xform;
        AcDbEntity* pE;
        if (acdbOpenObject(pE,m_int.m_idEntity,AcDb::kForWrite)==Acad::eOk)
                Acad::ErrorStatus es;
                if ((es=pE->transformBy(m_xform))!=Acad::eOk)
                        throw CmdException(es,"Transformation cannot be applied to object");
                pE->close();
void Jig3d::init(const AcDbObjectId& idEntity,const AcGePoint3d& refPoint,int viewportNumber) throw(CmdException)
        m_int.m_idEntity    = idEntity;
    m_refPoint          = refPoint;
    AcGsManager * pMan  = acgsGetGsManager();
    if (pMan==NULL)
        throw CmdException("Cannot get Gs manager");
    AcGsView * pView    = acgsGetGsView (viewportNumber, false);
    if (pView==0)
        throw CmdException("Perform this command in a 3d View.  Use the shademode command to activate one.");
    m_MSBObjectID       = GetModelSpaceBlockID();
    if (m_MSBObjectID.asOldId() == 0)
        throw CmdException("Unable to retrieve modelspace block ID");
    m_pModel            = pMan->getDBModel();
    if (m_pModel==NULL)
        throw CmdException("Unable to retrieve AcDb AcGsModel");
    AcGePoint3d pt(refPoint);
    m_elev = pt.z;
    m_pModel->onAdded  (&m_int, m_MSBObjectID.asOldId());
        m_mode = kMove;
void Jig3d::engage(void) throw(CmdException)
    char* prompt = "\nSpecify displacement or [Base point/X/Y/Z/Exit]:";
        do
                setDispPrompt(prompt);
                status = drag();
                switch (status)
                case AcEdJig::kKW1:
                                acedGetPoint(asDblArray(m_refPoint),"Specify base point:",asDblArray(m_refPoint));
                acdbUcs2Wcs(asDblArray(m_refPoint),asDblArray(m_refPoint),Adesk::kFalse);
                        else {
                                apply();
                                status = AcEdJig::kCancel;
                        break;
                case AcEdJig::kKW2:
                        assert(m_mode == kMove);
                        m_mode = kRotateX;
                        prompt = "Specify rotation around X axis or [Exit]:";
                        break;
                case AcEdJig::kKW3:
                        m_mode = kRotateY;
                        prompt = "Specify rotation around Y axis [Exit]:";
                        break;
                case AcEdJig::kKW4:
                        m_mode = kRotateZ;
                        prompt = "Specify rotation around Z axis [Exit]:";
                        break;
                case AcEdJig::kKW5:
                        apply();
                        break;
                default:
                                m_refPoint+=m_xformTemp.translation();
                        m_mode = kMove;
                        break;
        while (status != AcEdJig::kCancel);
void jig3d()
    try
        struct resbuf rb;
        acedGetVar("cvport", &rb);
        if (rb.resval.rint==1)
            throw CmdException("3djig cannot be used in layout mode");
        ads_name ename;
        ads_point pt;
                int rt;
        if ((rt = acedEntSel("Select object:",ename,pt))==RTCAN)
                        return;
                if (rt!=RTNORM)
                        throw CmdException(Acad::eInvalidInput,"Invalid selection. Try again!");
        AcDbObjectId id;
        acdbGetObjectId(id,ename);
        Jig3d jig;
        acdbUcs2Wcs(pt,pt,Adesk::kFalse);
        jig.init(id, asPnt3d(pt), rb.resval.rint);
        jig.engage();
    catch(CmdException e)
        const char* strDesc = e.description();
        if (strDesc == NULL)
            strDesc = "No description.";
        acutPrintf("ERROR:%s (es=%s)",strDesc,acadErrorStatusText(e.errorStatus()));
#if _MSC_VER > 1200
#pragma warning(pop)
#endif
相关的两个头文件:
//***CmdException.h**********
#if !defined(_CMDEXCEPTION_H)
#define _CMDEXCEPTION_H
#if _MSC_VER > 1000
#pragma once
#endif // _MSC_VER > 1000
class CmdException
    const char* m_strDesc;
    const Acad::ErrorStatus m_Es;
public:
    CmdException(const Acad::ErrorStatus es,const char* strDesc=NULL)
        :m_strDesc(strDesc),m_Es(es)
    CmdException(const char* strDesc)
        :m_strDesc(strDesc),m_Es(Acad::eInvalidInput)
    const char* description() const
                return m_strDesc;
    const Acad::ErrorStatus errorStatus() const
                return m_Es;
#endif
//***Intermediary.h*****
#if !defined(_INTERMEDIARY_H)
#define _INTERMEDIARY_H
#if _MSC_VER > 1000
#pragma once
#include "drawable.h"
class Intermediary : public AcGiDrawable
    AcGsNode* m_pNode;
        AcGeMatrix3d m_mat;
public:
    AcDbObjectId m_idEntity;
    void setTransform(const AcGeMatrix3d& mat)
        m_mat = mat;
        virtual Adesk::UInt32   setAttributes   (AcGiDrawableTraits * traits)
        return kDrawableIsCompoundObject;
    virtual Adesk::Boolean  worldDraw       (AcGiWorldDraw * wd)
        wd->geometry().pushModelTransform(m_mat);
        AcDbEntity* pE;
        if (acdbOpenObject(pE,m_idEntity,AcDb::kForRead)==Acad::eOk)
            wd->geometry().draw(pE);
                        pE->close();
        wd->geometry().popModelTransform();
        return Adesk::kTrue;
    virtual void            viewportDraw    (AcGiViewportDraw * vd)
        return;
    virtual Adesk::Boolean  isPersistent    (void) const
    virtual AcDbObjectId    id              (void) const
        return AcDbObjectId::kNull;
    virtual void            setGsNode       (AcGsNode * gsnode)
        m_pNode = gsnode;
    virtual AcGsNode*       gsNode          (void) const
        return m_pNode;
#endif
发表于 2006-1-23 12:31:18 | 显示全部楼层
现在还处在2D状态,3D的Jig还没搞过呢?
 楼主| 发表于 2006-1-23 13:11:35 | 显示全部楼层
谢谢RedCAD,我现在就需要2D的就行了,但这个程序是3D的,我想把它改成2D的,但改了好长时间都没搞顶,郁闷啊~~~眼看要过年了,这东西还搞不顶!你有2D的相关程序吗?发一个给我参考下吧,谢谢!
发表于 2006-1-23 15:12:36 | 显示全部楼层
能不能简单描述一下你的程序的思路呢?
看的有点费劲 :(
看了半天也没有搞清楚你在 Jig 中想画什么。。。
AcDbPolyline中加点?还是什么??
 楼主| 发表于 2006-1-23 16:32:40 | 显示全部楼层
这个程序其实不是我写的,是一个例子。在JIG中并没有想画什么,它主要是实现实体的拖动、旋转问题。我现在想把它改成多实体关联拖动,在3D效果下可以实现,但就是在2D的效果下不行,我看了好长时间,我想主要问题是在3D渲染后,程序是怎么样调用Intermediary类中的worlddraw()函数的,Intermediary是一个从AcGiDrawable派生出来的类。怎么样不经过3D渲染,而直接调用Intermediary类的worlddraw()函数,只要解决这个问题就OK了!
GMT+8, 2026-11-22 09:34 , Processed in 0.358411 second(s), 18 queries , Gzip On, File On.
