查看: 2235|回复: 15
[其他]:翘首以盼SUv5.0
发表于 2005-6-15 09:15:13 | 显示全部楼层 |阅读模式
新特征1 透空贴图
登录/注册后可看大图
This examples illustrates using an alphatransparent png as a material. The geometry of the model is extremely simple but the use of the png provides 'virtual' geometry. Modelling perforations with actual holes quickly overwhelms sketchup -- there soon becomes an extreme amount of edges. With a alphatransparent material it can look like there would be lots of edges when in fact there may be very few.
The image also illustrates a limitation --- the shadow engine doesn't recognize the transparent parts of the image. Depending on what you are trying to model this may or maynot be a problem.
 楼主| 发表于 2005-6-15 09:17:24 | 显示全部楼层
新特征2:顶点加强的显示模式
登录/注册后可看大图
The image also shows version 5's new blobby 'endpoints' display style -- it adds a blob to to the end of each line. In this case the lines also have extensions turned on.
 楼主| 发表于 2005-6-15 09:27:54 | 显示全部楼层
新特征3:sandbox
登录/注册后可看大图
Here is the sandbox in action; hills pulled up with the Smoove tool, roadbed laid down with the Stamp tool. The trees are utilising the new image transparency
 楼主| 发表于 2005-6-15 10:33:17 | 显示全部楼层
新特征4:超快的速度
登录/注册后可看大图
The first thing I noticed was the speed! Got to be at least 2x faster just as @Last claims.
发表于 2005-6-15 12:25:20 | 显示全部楼层
last software每年夏天都会给我们一些惊喜,期待中.........
 楼主| 发表于 2005-6-19 08:12:34 | 显示全部楼层
Su5的界面:
发表于 2005-6-19 10:02:48 | 显示全部楼层
哪里有下载地址?有没有破解文件?
发表于 2005-6-19 19:59:30 | 显示全部楼层
有没有破解文件?
发表于 2005-6-20 12:14:56 | 显示全部楼层
期待下载地址和破解文件上传!!!
发表于 2005-6-20 12:52:51 | 显示全部楼层
有没有破解版的下在啊?
发表于 2005-6-23 08:24:12 | 显示全部楼层
这个小家伙真是越来越强了~ 期待中....
发表于 2005-6-24 10:23:26 | 显示全部楼层
自己还先学好4了,再努力
发表于 2005-6-24 10:45:15 | 显示全部楼层
版面看上去就亲切了几分 哦
很是期待破解版的上传
发表于 2005-6-24 16:43:09 | 显示全部楼层
期待
发表于 2005-6-28 12:30:13 | 显示全部楼层
功能好强,哪里有下载地址?有没有相关学习资料?
GMT+8, 2026-11-22 08:56 , Processed in 0.487119 second(s), 38 queries , Gzip On, File On.
