查看: 1103|回复: 2
[VBA程序]:紧急求助:各位同仁,帮助看一下这段程序问题在哪里?
发表于 2005-7-28 12:45:43 | 显示全部楼层 |阅读模式
Sub ConnectLine()
Dim mySelect As AcadSelectionSet
Dim MyVal(0 To 3) As String
MyVal(0) = "8": MyVal(1) = "TbRegion": MyVal(2) = "0": MyVal(3) = "REGION"
BuildFilter fType, fDate, MyVal
Set sss = ThisDrawing.SelectionSets
On Error Resume Next
ThisDrawing.SelectionSets.Item("mySelects12").Delete
On Error GoTo ErrExit
Set myss = sss.Add("mySelects12")
myss.Select acSelectionSetAll, , , fType, fDate
Dim myExplode As Variant, En As AcadEntity
For Each En In myss
   myExplode = En.Explode
   Set mySelect = sss.Add("sRegions5")
   mySelect.AddItems myExplode   '当前选择集已经添加了对象
   '问题:为什么下一句中P提示前一个选择集合不存在
   ThisDrawing.SendCommand "_pedit" & vbCr & "M" & vbCr & "P" & vbCr & vbCr & "Y" & vbCr & "J" & vbCr & vbCr & vbCr
   mySelect.Delete
Next
Exit Sub
ErrExit:
   MsgBox Err.Description
End Sub
'创建选择集的过滤规则
Public Sub BuildFilter(typeArray As Variant, dataArray As Variant, ByVal gCodes As Variant)
Dim fType() As Integer, fData() As Variant
Dim Index As Long, i As Long
Index = LBound(gCodes) - 1
'根据gCodes的内容创建过滤数组
For i = LBound(gCodes) To UBound(gCodes) Step 2
    Index = Index + 1
    ReDim Preserve fType(0 To Index)
    ReDim Preserve fData(0 To Index)
    fType(Index) = CInt(gCodes(i))
    fData(Index) = gCodes(i + 1)
Next
'返回值
typeArray = fType
dataArray = fData
End Sub*-*6
发表于 2005-7-31 13:58:33 | 显示全部楼层
pedit 的命令只能在键入命令后再选择图元
可以在键入pedit M 后 ,在选择集中循环发送图元的句柄
发表于 2005-8-1 08:24:07 | 显示全部楼层
不用for循环,直接创建你的选择集就行
不用for循环,直接创建你的选择集就行
Sub Pline()
Dim sset As AcadSelectionSet
ThisDrawing.SelectionSets.Item("LineSet").Delete
Set sset = ThisDrawing.SelectionSets.Add("LineSet")
sset.SelectOnScreen
ThisDrawing.SendCommand "_pedit" & vbCr & "M" & vbCr & _
"p" & vbCr & vbCr & "Y" & vbCr & "J" & _
vbCr & vbCr & vbCr
End Sub
GMT+8, 2026-11-22 11:30 , Processed in 0.351142 second(s), 17 queries , Gzip On, File On.
