查看: 1632|回复: 11
[推荐]:3ds Max 8 (揭开面纱)
已领礼包: 6个
发表于 2005-8-2 00:31:13 | 显示全部楼层 |阅读模式
→→想找3DS MAX 6.0 完美中文版等软件可以在这里找找←←[/COLOR]
3ds Max 8 (揭开面纱):
3ds Max 8.0 令人期待已久的一个版本,于2005.8.1亮相SIGGRAPH 2005。以下我们看看揭开他的神秘面纱!
Autodesk 在SIGGRAPH 2005上发布 3ds Max 8
登录/注册后可看大图
*-*c
SAN RAFAEL, Calif.—August 1, 2005—Autodesk, Inc. (NASDAQ: ADSK), today announced Autodesk 3ds Max 8 software, the latest version of its award winning 3D modeling, animation and rendering solution. Designed to provide the most comprehensive and advanced 3D design tools and pipeline workflow, 3ds Max is one of the industry’s most popular solutions for games production, film and video production and design visualization.
价格:
Autodesk 3ds Max 8 software $3,495.
3ds Max 7 到 3ds Max 8 升级版 US $795.
主要特征:
Create your own reality.
Image courtesy of Funcom
Manage challenging creative projects. Achieve better results in less time. Autodesk® 3ds Max® 8 software delivers flexible, state-of-the-art, productive tools designed for 3D artists in many industries—game development, design visualization, and visual effects.
Expanding an already robust toolset, 3ds Max 8 provides new and enhanced functionality in areas of character development, asset management, and scripting tools.
Animation
View Larger Image
Mix, edit, and transition motions from any 3ds Max animation. Import standard motion capture formats directly to your character rig. Use our new open file format based on XML to write motion files from custom tools and bring them into 3ds Max. Develop photorealistic characters with our improved character development features, cloth and hair simulation tools, award-winning Reactor® physics system, and particle flow.
Modeling
View Larger Image
Extensive, industry-best polygon tools for low- or high-resolution modeling. New, superior polygon modeling tools accelerate the process of adding detail to geometry. Use our fast, unique Edit Poly approach to create everything from simple to complex models.
UV Mapping Tools
View Larger Image
Control unfolding of UV seams with pelt mapping. Create a flat, unified map for texturing your objects by stretching out UVW coordinates. Relax UVs and remove distortion by accurately matching UVs to object geometry. Save tremendous amounts of time and hours of work since seams are exactly where they should be and rarely—if ever—need adjusting afterwards.
Skinning
View Larger Image
Skin anything from low polygon, high-quality game meshes to the most dense of visual effects models. Vertices are now assigned to a bone by default to prevent unwanted stretching and minimize the need to edit envelopes.
Maxscript Scripting Language
View Larger Image
Build solid Maxscripts in less time with our new Maxscript debugger. Add custom functionality into tools with full control over the user interface. Use this object-oriented scripting language to create scripts to extend your 3ds Max toolset, or to optimize your workflow throughout your pipeline.
Customer Showcase
Check out our customers’ amazing work in the 3ds Max showcase.
相关报道:
http://usa.autodesk.com/adsk/ser ... &linkID=5572942
技术手册:
http://images.autodesk.com/adsk/files/3dsMax8_techspec_LTRppc.pdf
登录/注册后可看大图
登录/注册后可看大图
发表于 2005-8-3 00:24:18 | 显示全部楼层
在哪里能搞到
发表于 2005-8-3 09:29:49 | 显示全部楼层
软件升级的可真是快,7还没有用过呐,8都出来了!
发表于 2005-8-3 22:21:31 | 显示全部楼层
太快了!呵呵
发表于 2005-8-3 22:49:00 | 显示全部楼层
出得太快了吧,我才用上7没几天啊。
发表于 2005-8-5 14:48:52 | 显示全部楼层
都有偿8拉,我厂5都还没摸透
发表于 2005-8-5 14:59:28 | 显示全部楼层
太快了,max6都没摸熟。
已领礼包: 2个
发表于 2005-8-5 15:59:10 | 显示全部楼层
的确是太快了。我5都还不怎么会,这就出8了。
发表于 2005-8-7 16:52:51 | 显示全部楼层
是32位的还是64位的软件啊?期待64位的MAX,这样随便可以打灯了,,爽啊,,,正在考虑计划卖64位CPU的机子中,,,,到时候可就用得上了,,呵呵,,,,
发表于 2005-8-7 16:53:44 | 显示全部楼层
速度
发表于 2005-8-8 18:28:28 | 显示全部楼层
AUTODESK现在是靠升级吃饭了,一年一个版本,真正实质的改变并没有多少?还是先从基础学起,不要跟着软件走。
发表于 2005-8-9 13:37:12 | 显示全部楼层
升级太快了,就画画效果图的话也不用这么高的版本。
GMT+8, 2026-11-2 22:51 , Processed in 0.552141 second(s), 54 queries , Gzip On.
