查看: 32305|回复: 101
[下载]:下载汇总
发表于 2003-3-28 09:29:23 | 显示全部楼层 |阅读模式
MS下载
[从MS的版本号推出下载地址!
我们比较一下这几个地址:
ftp://ftp2.bentley.com/dist/select/...s07020420en.exe
ftp://ftp2.bentley.com/dist/select/...s08000401en.exe
ftp://ftp2.bentley.com/dist/select/...s08010007en.exe
ftp://ftp2.bentley.com/dist/select/...s08010109en.exe
从这几个地址我们可以得出一个结论:下载地址只与版本号有关!
想知道Bentley最新发布的版本号,只要去官方站点http://selectservices.bentley.com/d...m查一下就行了!
最新版本 ms2004   提供日期: 2004.6
ftp://ftp2.bentley.com/dist/sele ... en/ms08050064en.exe
ms 2004中文版 ftp://ftp2.bentley.com/dist/sele ... zh/ms08050064zh.exe
geographics  提供日期: 2004.6
ftp://ftp2.bentley.com/dist/sele ... en/gg08050035en.exe
ms descartes 2004
ftp://ftp2.bentley.com/dist/sele ... en/dc08050061en.exe
v8的mdl帮助
ftp://ftp2.bentley.com/dist/sele ... n/mdl08050125en.exe
一。Geographics 用户指南-中文版
http://draw.xdcad.net/show.php?id=2594
http://draw.xdcad.net/show.php?id=2595
http://draw.xdcad.net/show.php?id=2596
http://draw.xdcad.net/show.php?id=2597
二。V8中文培训资料2d和3d
       见后面的帖子
五。MicroStation 8.1 中的数字签名及数字权利技术
http://www.xdcad.net/forum/attachment.php?s=&postid=212974
六。Bentley PlantSpace Design Series (PDS)  V08.00.02.12
最低要求工作平台:
MicroStation V8 08.00.02.20
MicroStation TriForma 08.00.02.14
共20个文件
http://www.xdcad.net/forum/attachment.php?s=&postid=184326
http://www.xdcad.net/forum/attachment.php?s=&postid=184328
http://www.xdcad.net/forum/attachment.php?s=&postid=184329
http://www.xdcad.net/forum/attachment.php?s=&postid=184330
http://www.xdcad.net/forum/attachment.php?s=&postid=184332
http://www.xdcad.net/forum/attachment.php?s=&postid=184335
http://www.xdcad.net/forum/attachment.php?s=&postid=184336
http://www.xdcad.net/forum/attachment.php?s=&postid=184337
http://www.xdcad.net/forum/attachment.php?s=&postid=184338
http://www.xdcad.net/forum/attachment.php?s=&postid=184339
http://www.xdcad.net/forum/attachment.php?s=&postid=184340
http://www.xdcad.net/forum/attachment.php?s=&postid=184353
参见这个帖子
http://www.xdcad.net/forum/showthread.php?s=&threadid=36944
七。BENTLEY MicroStation GeoGraphics v8.00 04 03
MicroStation GeoGraphics是为绘图人员、土木工程和规划专业技術人員专门设计的, 具有这是一个含有广泛的制图工具的工具箱,可做为电脑辅助设计与地理信息系统之间的桥梁,同时也建立了一个地理工程的解决方案。MicroStation GeoGraphics结合了符合工业标准的资料撷取及编辑的工具。而且它含有综合的资料库介面以及一个强大的空间分析引擎。这让用户能够输入、确认、管理、分析以及显示地理资料。同时MicroStation GeoGraphics也拥有管理由向量资料、光栅资料与非空间属性所组成的各种资料结合体的能力.
下载见帖子
http://www.xdcad.net/forum/showthread.php?s=&threadid=39426
八。MicroStation Schematics V08.00.01.27
最低要求MicroStation V8.00.02.20
下载见帖子
http://www.xdcad.net/forum/showthread.php?s=&threadid=37698
九。Iras.B.v8.1 MS矢量化软件
下载见帖子
http://www.xdcad.net/forum/showthread.php?s=&threadid=40228
十。microstation triform用户手册(中文)
下载见帖子
http://www.xdcad.net/forum/showthread.php?s=&threadid=46680
十一. Bentley Descartes 2004 Edition -08050035En
ftp://ftp2.bentley.com/dist/sele ... en/dc08050035en.exe
MSv8.1.0.7 的license  见附件
关于一些常见问题 请不要在开贴询问了[/COLOR]
1 关于ms的中文资料
   有msv8  ms j 的使用教程 在大书店有的
  其它资料只有英文的
2 关于 ms的中文开发资料
  没有中文的 如果有我会发贴给大家的 请不要再问了
  在VC下开发mdl 设置
  http://sumbera.com/ustation/research/vc6ide.htm
3 关于不能下载的问题
   bently的下载是他们自己的问题 时间长了当然就下载不了了
   bently的服务器是 ftp://ftp.bentley.com 可以自己找找 有很多东西的   论坛上自己的下载应该都是可以 不行的话 如果需要在重新上传
4 J板ma应用程序才能运用于v8版本下
   不能用的 变化太大了 只能重新编译
 楼主| 发表于 2004-6-26 21:20:08 | 显示全部楼层
V8中文培训资料2d 和3d (共2个)
 楼主| 发表于 2004-6-27 17:44:08 | 显示全部楼层
发表于 2004-7-4 02:37:17 | 显示全部楼层
[下载]:可下載rebar2004的地址
发表于 2004-7-4 10:36:42 | 显示全部楼层
[下载]:Bentley.MX.2004.Edition介绍及license
MX 產品線提供以線串(string)為基礎的土木工程解決方案,涵蓋道路、鐵路與整地設計。MX具備優異的跨平台特性,您可自由選用MicroStation、AutoCAD或是Windows版本的操作環境。MX產品家族採用了功能強大但精簡的核心技術—3D線串塑模。 共通之數據庫讓您可在最常見的AEC CAD平台或獨立平台中建立及標註3D模型。 這意味著您可以在一CAD環境中進行方案設計並儲存後,在另一個CAD環境無礙地開啟此方案,完全沒有數據遺失的問題。
※Bentley MXROAD 為一套快速且精確的道路設計工具。 藉由其獨特的線串塑模技術,您可以迅速地建構數種可行方案,以獲致最佳化之設計。
※Bentley MXRENEW 為一鋪面更新軟件,協助您最佳化鋪面設計與用料,以有效掌握經費支出。
※Bentley MXURBAN 為一針對都市與市郊之道路設計軟件。 例如它可藉由邊緣線推向中心線的設計方式,確保符合設計之限制條件。
※Bentley MXRAIL 為一鐵路設計與道岔配置之設計工具;可用於現有鐵路之維護與更新,以及輕軌、高速與通勤電車等各類型之鐵路設計。
※Bentley MXSITE 為一適用於各類土地分區之高效率整地設計軟件。
发表于 2004-7-4 11:54:00 | 显示全部楼层
想必NMD是高手,也多给我们介绍点.
不知和INROADS有什么大的区别?
还是就是INROADS的下一代产品?
谢谢!
 楼主| 发表于 2004-7-4 13:19:41 | 显示全部楼层
MicroStation TriForma 2004 08.05.00.71
ftp://ftp2.bentley.com/dist/sele ... en/tf08050071en.exe
Bentley PlantSpace Design Series 08.05.00.21
ftp://ftp2.bentley.com/dist/sele ... /psds08050021en.exe
Bentley View 2004 08.05.00.61
ftp://ftp2.bentley.com/dist/sele ... en/vw08050071en.exe
Bentley Structural 2004 08.05.00.71
要求MicroStation TriForma 2004 Edition 08.05.00.71
ftp://ftp2.bentley.com/dist/sele ... n/stf08050071en.exe
Bentley Architecture 2004 08.05.00.58
ftp://ftp2.bentley.com/dist/sele ... n/arc08050058en.exe
发表于 2004-7-8 16:19:34 | 显示全部楼层
发表于 2004-7-8 19:53:08 | 显示全部楼层
我下了,试用了下,好象MX是MOSS的下代产品.支持很多图形平台.并且也可以在WIN下独立运行.不过用下来发现易用性不强.好象是BENTLEY产品的通病.
我现在用的是AUTODESK LDT 2004+MX ,map 3d 2004+mx也可以的
希望高手能给给我们扫盲.
MOSS这个软件我以前都没听说过.上次到武大时,听一个测绘学院的老师说的.讲MOSS在公路测量方面和出色.不过以前一直没有这个软件的资料.
发表于 2004-7-9 09:33:50 | 显示全部楼层
下了,但不知怎么用。MX2004和INRODS及GEOPAK ROAD有什么区别?望指教。
发表于 2004-7-10 11:03:33 | 显示全部楼层
[推荐]:繁体中文版ms2004下载,版本08050064
斑竹提示: ms新版本的发布请到置顶的帖子[/COLOR]
发表于 2004-7-10 16:15:14 | 显示全部楼层
我下了,不过能否提供一下简体中文版,能详细说一下与inroads与geopak的区别吗
发表于 2004-7-12 11:02:51 | 显示全部楼层
不知道按照bentley的速度,要什么时候才能推出MS2004简体中文版?期待啊
发表于 2004-7-12 15:21:51 | 显示全部楼层
看样子就没想出,连8.1版的都是较旧的。
发表于 2004-7-17 11:06:42 | 显示全部楼层
繁体中文版的最后两个字母是什么?
GMT+8, 2026-11-22 11:50 , Processed in 0.380917 second(s), 38 queries , Gzip On, File On.
