查看: 1333|回复: 5
[求助] [求助]:菜鸟求助提出字符
发表于 2005-8-10 14:22:09 | 显示全部楼层 |阅读模式
在autoliap中,setq s (getvar "cDATE"))得到系统的日期:20050810.14180358(只读)
可否有有命令像car那样,从左到右一个一个字的提取到不同的变量中
发表于 2005-8-10 14:38:13 | 显示全部楼层
请查看substr函数的帮助文件。
已领礼包: 111个
发表于 2005-8-10 14:48:07 | 显示全部楼层
;用此行: (setq s (mapcar '(lambda(x)(chr x)) (vl-string->list (rtos (getvar  "cdate") 2 20)))) 可达到目的
;Command: (setq s (mapcar '(lambda(x)(chr x)) (vl-string->list (rtos (getvar  "cdate") 2 20))))
;("2" "0" "0" "5" "0" "8" "1" "0" "." "1" "4" "4" "4" "2" "2" "3" "4")
发表于 2005-8-11 10:03:16 | 显示全部楼层
不错!
 楼主| 发表于 2005-8-11 10:27:01 | 显示全部楼层
好强啊,就是看不大懂
已领礼包: 9346个
发表于 2005-8-11 13:48:41 | 显示全部楼层
Command: (menucmd "M=$(edtime,$(getvar,date),YY-MO-DD)")
"05-08-11"
Command: (menucmd "M=$(edtime,$(getvar,date),YY/MO/DD)")
"05/08/11"
Command: (menucmd "M=$(edtime,$(getvar,date),YY MO DD)")
"05 08 11"
Command: (menucmd "M=$(edtime,$(getvar,date),YYYY MO DD)")
"2005 08 11"
Command: (menucmd "M=$(edtime,$(getvar,date),YYYY)")
"2005"
Command: (menucmd "M=$(edtime,$(getvar,date),Mo)")
"08"
Command: (menucmd "M=$(edtime,$(getvar,date),DD)")
"11"
GMT+8, 2026-11-6 14:27 , Processed in 0.492389 second(s), 41 queries , Gzip On.
