查看: 916|回复: 5
[讨论]:在acad2000中屏幕菜单太宽了,字却太小,该如何设置?
发表于 2002-4-24 03:36:48 | 显示全部楼层 |阅读模式
已领礼包: 145个
发表于 2002-4-24 03:39:32 | 显示全部楼层
Re: [讨论]:在acad2000中屏幕菜单太宽了,字却太小,该如何设置?
最初由 263net18 发布
[B]在acad2000中屏幕菜单太宽了,字却太小,该如何设置? [/B]
屏幕菜单宽没有办法,升级到2002吧,不知道为什么你还在用2000,2000的地位就是当年的R13。
字可以通过修改ACADRES.DLL来实现,论坛以前讨论过,搜索下。
 楼主| 发表于 2002-4-24 05:15:08 | 显示全部楼层
我以前一直用r14,在网上下了acad2000(中文)。。。。
我以前一直用r14,在网上下了acad2000(中文)和acad2002,装完后后者只能用到2001年7月,只好用2000版。袋子里缺少银子,只能用D版。:)。盼哪位好心的老哥能给个连接!emile:zwzheng@21cn.com  QQ:93968074。
已领礼包: 24个
发表于 2002-4-24 10:08:20 | 显示全部楼层
街上到处都是*版的AutoCAD 2002 简体中文正式版,何不买一张?
发表于 2002-4-24 10:16:36 | 显示全部楼层
最初由 263net18 发布
<body>
<p class="BannerBase">Editing screen menu size in a user profile</p>
<hr>
<p class="tdhead1">Issue</p>
<p class="tdtext">The screen menu covers your entire screen. No text or handles
are visible, so you are unable to resize it. All you can do is turn the screen
menu on and off using the OPTIONS command.</p>
<p class="tdhead1">Solution</p>
<p class="tdtext">Information about the state and position of the screen menu
toolbar is stored in user profiles. You can export your user profile, and edit
it using text editing software to remove the screen menu toolbar settings, and
then import the modified profile back into AutoCAD<sup>?/SUP&gt;. This is the
preferred method, rather than editing the system registry directly.<br>
<br>
</p>
<p class="tdtext">To edit the user profile:</p>
<ol class="tdnumberedlist">
  <li>Type <b>options</b> on the command line.
  <li>In the Options dialog box, select the Profiles tab and then select the
    user profile you are currently using.
  <li>Select Export and then enter a file name and location for the file. Choose
    OK to export the file.
  <li>Using text editing software, open the file you exported in step 3.
  <li>Search for the following text: ScreenMenu. You should find three lines
    beginning with the text &quot;ScreenMenu&quot;, similar to the following:
    <p class="tdtext">&nbsp;</p>
    <p class="tdcode">&quot;ScreenMenu&quot;=dword:00000001<br>
    &quot;ScreenMenu.Style&quot;=dword:00000000<br>
    &quot;ScreenMenu.Position&quot;=&quot;437 128 531 545&quot;review
    background&quot;=dword:00FFFFFF</p>
    <b>
    <p class="tdnoteortip">Note:</b> In your file, the values displayed after
    the equal sign may be different or some of these lines may be missing.</p>
  <li>Delete all of the lines that include the ScreenMenu text and save your
    changes.
  <li>In AutoCAD, select Import on the Profiles tab and select the file you
    edited in step 6.
  <li>In the Import Profile dialog box, specify a different profile name than
    the one you are currently using.
  <li>Choose Apply &amp; Close to import the new profile.
  <li>Select the new profile and then select Set Current to make the new profile
    current.
  <li>In the Options dialog box select the Display tab.
  <li>Select the Display Screen Menu check box and then choose Apply.</li>
</ol>
<p class="tdtext">The screen menu will be docked to the right side of the
application.</p>
<p class="tdnoteortip"><b>Note:</b> If you want to use the original profile name
you can delete the old profile and rename the newly imported profile using the
original name.</p>
</sup>
</body>
发表于 2002-4-24 10:17:43 | 显示全部楼层
Shit! 不支持html.
Editing screen menu size in a user profileIssue
The screen menu covers your entire screen. No text or handles are visible, so you are unable to resize it. All you can do is turn the screen menu on and off using the OPTIONS command.
Solution
Information about the state and position of the screen menu toolbar is stored in user profiles. You can export your user profile, and edit it using text editing software to remove the screen menu toolbar settings, and then import the modified profile back into AutoCAD?/SUP>. This is the preferred method, rather than editing the system registry directly.
Type options on the command line.
In the Options dialog box, select the Profiles tab and then select the user profile you are currently using.
Select Export and then enter a file name and location for the file. Choose OK to export the file.
Search for the following text: ScreenMenu. You should find three lines beginning with the text "ScreenMenu", similar to the following:
&nbsp;"ScreenMenu"=dword:00000001
"ScreenMenu.Style"=dword:00000000
"ScreenMenu.Position"="437 128 531 545"review background"=dword:00FFFFFFNote: In your file, the values displayed after the equal sign may be different or some of these lines may be missing.
Delete all of the lines that include the ScreenMenu text and save your changes.
In AutoCAD, select Import on the Profiles tab and select the file you edited in step 6.
In the Import Profile dialog box, specify a different profile name than the one you are currently using.
Choose Apply & Close to import the new profile.
Select the new profile and then select Set Current to make the new profile current.
The screen menu will be docked to the right side of the application.
Note: If you want to use the original profile name you can delete the old profile and rename the newly imported profile using the original name.
GMT+8, 2026-11-3 04:13 , Processed in 0.662272 second(s), 42 queries , Gzip On.
