查看: 720|回复: 0
[ARX程序]:帮我看看,关于图层方面的
发表于 2003-3-29 23:51:49 | 显示全部楼层 |阅读模式
void chgEntLayer(ads_name sel,long lenSS;)
        ads_name ssEntName;
        int rc,i;
        char* lyrname = "line";
        AcDbLayerTable *pLyrTable;
        Adesk::Boolean current = TRUE;
        AcDbLayerTableRecord *pLyrTblRecord;
        AcDbObjectId layerId,entId;
        AcDbEntity *pEnt;
        AcDbDatabase *pCurDb = NULL;
        pCurDb = acdbHostApplicationServices()->workingDatabase();
        pCurDb->getLayerTable(pLyrTable, AcDb::kForRead);
        // Check to see if the layer name exists
        if(pLyrTable->has(lyrname))
                pLyrTable->getAt(lyrname, pLyrTblRecord, AcDb::kForWrite, Adesk::kFalse);
                // pLyrTblRecord now points at the layer table record
                // which was opened for write
                pLyrTblRecord->setIsFrozen(Adesk::kFalse);
        else
                // Note how we can change the open mode
                // of the layer table from AcDb::kForRead
                // to AcDb::kForWrite
                pLyrTable->upgradeOpen();
                pLyrTblRecord = new AcDbLayerTableRecord;
                pLyrTblRecord->setName(lyrname);
                pLyrTable->add(pLyrTblRecord);
        // Get the layer Table ObjectId
        layerId = pLyrTblRecord->objectId();
        acedSSLength(sel,&lenSS);
        for(i = 0; i<lenSS; i++)
                rc = acedSSName(sel,i,ssEntName);
                if(rc != RTNORM)
                        break;
                acdbGetObjectId(entId,ssEntName);
                acdbOpenAcDbEntity(pEnt,entId,AcDb::kForWrite);
                pEnt->setLayer(layerId);//这个地方不能将layerId所代表的图层设为pEnt的图层
                pEnt->close();
        pLyrTblRecord->close();
        pLyrTable->close();
使图层为当前图层
        if(current
                pCurDb->setClayer(recId);
我调了很长时间,也没有效果,请帮帮忙
GMT+8, 2026-11-3 12:14 , Processed in 0.593055 second(s), 32 queries , Gzip On.
