查看: 2115|回复: 3
[LISP函数]:RGB转化为Truecolor
发表于 2005-9-6 00:43:30 | 显示全部楼层 |阅读模式
  1. ;;RGB -> TrueColor
  2. ;;(RGBtoOLE_color '(123 125 168))
  3. (defun RGBtoOLE_color (RGB-codes / r g b)
  4.   (setq r (lsh (car RGB-codes) 16))
  5.   (setq g (lsh (cadr RGB-codes) 8))
  6.   (setq b (caddr RGB-codes))
  7.   (+ (+ r g) b)
  8. )
发表于 2005-10-1 09:58:54 | 显示全部楼层
cad的truecolor是负数,这个转换程序是正数,有何关联?
 楼主| 发表于 2005-10-1 10:06:32 | 显示全部楼层
_$ (xdl-oletorgb (cdr (assoc 420 (entget (entlast)))))
(56 199 177)
_$ (xdl-rgbtoole '(56 199 177))
3721137
_$ (cdr (assoc 420 (entget (entlast))))
3721137
_$ (xdl-rgbtoaci '(56 199 177))
123
_$ (cdr (assoc 62 (entget (entlast))))
123
_$ (vla-get-color (vlax-ename->vla-object (entlast)))
123
_$ (assoc 420 (entget (entlast)))
(420 . 3721137)
_$ (assoc 62 (entget (entlast)))
(62 . 123)
_$
发表于 2005-10-1 14:38:54 | 显示全部楼层
与
(entmod  (append (entget (entlast)) (list(cons 62 123))))
(vla-get-EntityColor(vla-get-truecolor (vlax-ename->vla-object (entlast))))
-1023410053
的 entitycolor 有何内在联系?
GMT+8, 2026-11-22 10:31 , Processed in 0.408991 second(s), 16 queries , Gzip On, File On.
