查看: 1012|回复: 0
[LISP函数]:制作Donut
发表于 2005-9-8 09:53:23 | 显示全部楼层 |阅读模式
  1. ;;制作 Donut
  2. ;;;画圆环 r1内径r2 外 径
  3. (defun xd-MkDonut (p0 r1 r2 / P1 P2 R RR ent)
  4.   (setq        r  (/ (+ r1 r2) 2.0)
  5.         rr (- r2 r1)
  6.         p1 (polar p0 0 (- r))
  7.         p2 (polar p0 0 r)
  8.   )
  9.   (if (setq ent        (entmakex (list        '(0 . "LWPOLYLINE")
  10.                                 '(100 . "AcDbEntity")
  11.                                 '(67 . 0)
  12.                                 '(100 . "AcDbPolyline")
  13.                                 '(90 . 2)
  14.                                 '(70 . 1)
  15.                                 '(38 . 0.0)
  16.                                 '(39 . 0.0)
  17.                                 (cons 10 p1)
  18.                                 (cons 40 rr)
  19.                                 (cons 41 rr)
  20.                                 '(42 . 1.0)
  21.                                 (cons 10 p2)
  22.                                 (cons 40 rr)
  23.                                 (cons 41 rr)
  24.                                 '(42 . 1.0)
  25.                           )
  26.                 )
  27.       )
  28.     ent
  29.   )
  30. )
  31. (defun xd-addpline (vla-obj pts)
  32.   (vla-addlightweightpolyline
  33.     vla-obj
  34.     (vlax-make-variant
  35.       (vlax-safearray-fill
  36.         (vlax-make-safearray
  37.           vlax-vbdouble
  38.           (cons 0 (1- (* 2 (length pts))))
  39.         )
  40.         (apply 'append
  41.                (mapcar '(lambda (x) (list (car x) (cadr x))) pts)
  42.         )
  43.       )
  44.     )
  45.   )
  46. )
  47. ;;;画圆环 r1内径r2 外 径
  48. (defun xd-adddonut (obj p0 r1 r2 / r w p1 p2 pln)
  49.   (setq        r  (/ (+ r1 r2) 2.)
  50.         w  (abs (- r1 r2))
  51.         p1 (polar p0 0. r)
  52.         p2 (polar p0 pi r)
  53.   )
  54.   (setq pln (xd-addpline obj (list p1 p2)))
  55.   (mapcar '(lambda (x) (vla-setBulge pln (car x) (cdr x)))
  56.           '((0 . 1.0) (1 . 1.0))
  57.   )
  58.   (vla-put-ConstantWidth pln w)
  59.   (vla-put-closed pln :vlax-true)
  60.   pln
  61. )
GMT+8, 2026-11-22 10:30 , Processed in 0.327466 second(s), 10 queries , Gzip On, File On.
