查看: 2278|回复: 4
[求助] [弹指神通]:求助:vla-GetLoopAt函数怎么使用???
发表于 2005-9-13 13:45:55 | 显示全部楼层 |阅读模式
      vla-getloopat 为取得的hatch对象的环对象,相关资料很少,其后的参数不知是什么
发表于 2005-9-13 14:49:08 | 显示全部楼层
GetLoopAt Method
Gets the hatch loop at a given index.
See Also | Example
Signature
object.GetLoopAt Index, Loop
Object
Hatch
The object or objects this method applies to.
Index
Integer; input-only
A positive integer beginning with 0.
Loop
Variant (object or array of objects); output-only
An object or array of objects that makes up the loop.
发表于 2007-6-8 16:40:42 | 显示全部楼层
有会的给举个例子好吗,这个问题困绕我许多年了!
发表于 2007-6-9 09:16:04 | 显示全部楼层
(vla-invoke-method   hatobj  1 'lp)
lp 变量就是你要的
发表于 2016-9-27 00:48:47 | 显示全部楼层
  1. (vl-load-com)
  2. (defun c:Example_GetLoopAt()
  3.     ;; This example creates an associative hatch in model space.
  4.     ;; It then finds the objects that make up the first loop of the hatch.
  5.     (setq acadObj (vlax-get-acad-object))
  6.     (setq doc (vla-get-ActiveDocument acadObj))
  7.     (setq modelSpace (vla-get-ModelSpace doc))
  8.
  9.     ;; Define the hatch
  10.     (setq patternName "ANSI31"
  11.           patternType acHatchPatternTypePreDefined
  12.           bAssociativity :vlax-true)
  13.
  14.     ;; Create the associative Hatch object
  15.     (setq modelSpace (vla-get-ModelSpace doc))
  16.     (setq hatchObj (vla-AddHatch modelSpace patternType patternName bAssociativity acHatchObject))
  17.
  18.     ;; Create the outer loop for the hatch.
  19.     ;; An arc and a line are used to create a closed loop.
  20.     (setq center (vlax-3d-point 5 3 0)
  21.           radius 3
  22.           startAngle 0
  23.           endAngle 3.141592)
  24.
  25.     (setq arcObj (vla-AddArc modelSpace center radius startAngle endAngle))
  26.     (setq lineObj (vla-AddLine modelSpace (vla-get-StartPoint arcObj) (vla-get-EndPoint arcObj)))
  27.     (setq outerLoop (vlax-make-safearray vlax-vbObject '(0 . 1)))
  28.     (vlax-safearray-put-element outerLoop 0 arcObj)
  29.     (vlax-safearray-put-element outerLoop 1 lineObj)
  30.     ;; Append the outer loop to the hatch object
  31.     (vla-AppendOuterLoop hatchObj outerLoop)
  32.
  33.     ;; Append the first circle as one inner loop
  34.     (setq center (vlax-3d-point 5 4.5 0)
  35.           radius 1)
  36.     (setq innerLoop1 (vlax-make-safearray vlax-vbObject '(0 . 0)))
  37.     (vlax-safearray-put-element innerLoop1 0 (vla-AddCircle modelSpace center radius))
  38.     (vla-AppendInnerLoop hatchObj innerLoop1)
  39.
  40.     ;; Append the second circle as the other inner loop
  41.     (setq radius 0.5)
  42.     (setq innerLoop2 (vlax-make-safearray vlax-vbObject '(0 . 0)))
  43.     (vlax-safearray-put-element innerLoop2 0 (vla-AddCircle modelSpace center radius))
  44.     (vla-AppendInnerLoop hatchObj innerLoop2)
  45.
  46.     ;; Evaluate and display the hatch
  47.     (vla-Evaluate hatchObj)
  48.     (vla-Regen doc :vlax-true)
  49.
  50.     ;; Find the objects that make up the first loop
  51.     (vla-GetLoopAt hatchObj 0 'loopObjs)
  52.
  53.     ;; Find the types of the objects in the loop
  54.     (setq I 0
  55.           objName "")
  56.     (while (>= (vlax-safearray-get-u-bound loopObjs 1) I)
  57.         (setq objName (strcat objName (vla-get-ObjectName (vlax-safearray-get-element loopObjs I)) ", "))
  58.         (setq I (1+ I))
  59.     )
  60.
  61.     (alert (strcat "The objects in the first loop of the hatch are: " objName))
  62. )
GMT+8, 2026-11-5 22:53 , Processed in 0.421382 second(s), 40 queries , Gzip On.
