查看: 995|回复: 3
[LISP程序]:如何判断一个点是否在一条直线上??
发表于 2005-9-26 19:12:59 | 显示全部楼层 |阅读模式
如何判断一个点是否在一条直线上??
发表于 2005-9-26 19:46:10 | 显示全部楼层
  1. [FONT=courier new](defun c:test (/ curve-obj point)
  2.   (setq        curve-obj (car (entsel "\n选择物体 : "))
  3.         point          (getpoint "\n点或坐标 : ")
  4.   )
  5.   (if (vlax-curve-getParamAtPoint curve-obj point)
  6.     (princ "点在曲线上!")
  7.     (princ "点不在曲线上!!")
  8.   )
  9.   (princ)
  10. )[/FONT]
发表于 2005-9-29 15:44:58 | 显示全部楼层
;;;判断点在线段上,是=1,否=0,端点上=2
(defun p-line (p l / a line ls le b c d ponl)
;;;p-点,l-直线图元名
  (setq        a    (list (car p) (cadr p))
        line (entget l)
        ls   (list (cadr (assoc 10 line)) (caddr (assoc 10 line)))
        le   (list (cadr (assoc 11 line)) (caddr (assoc 11 line)))
        b    (distance ls a)
        c    (distance a le)
        d    (distance ls le)
  (if (or (< b 0.005) (< c 0.005))
    (setq ponl 2)
    (if        (< (abs (- (+ b c) d)) 0.005)
      (setq ponl 1)
      (setq ponl 0)
发表于 2005-9-29 18:20:41 | 显示全部楼层
可看看eachy在程序库的
点到直线距离,数学方法求
GMT+8, 2026-10-16 13:32 , Processed in 0.429966 second(s), 38 queries , Gzip On.
