查看: 1360|回复: 8
[必看]:CHIEF ARCHITECT 9.0 新功能介绍!!!
发表于 2003-4-11 20:31:59 | 显示全部楼层 |阅读模式
恕我不翻译了,一句话再这样下去的话,CHIEF 要追上AC了,至少现在在3D编辑和渲染方面已经追上甚至超过了!
1
"New in Chief Architect 9.0" Features
3D Views
3D editing available in all 3D views, including Render View
Save 3D/Render cameras
Glass House view allows view of building interior, exterior, and spatial relationships
simultaneously
Mouse 3D camera movement including orbit, pan, and walkthrough
Photo-realistic ray-tracing with reflections and radiosity
Expanded 3D editing:
- Ability to place objects directly into all 3D/Render views (windows, doors,
cabinets, objects, electrical, etc.)
- Ability to copy and paste of 3D objects in 3D/Render views
- Place hardware onto cabinets/doors in 3D/Render views
- Place sinks and countertop items in 3D/Render views
- Full 3D editing of electrical items, corner boards, quoins, framing members,
trusses
- Double-click in 3D/Render views to edit stairs, countertops, slabs
- Apply door/cabinet styles in 3D/Render views
Auto-Detailing automatically fills in details in your cross-section views, including
insulation, foundations, and wall layers
Material painter allows you to apply materials to individual objects in 3D/Render views
Faster drawing in 3D/Render Views
"Low-Detail" 3D mode available for fast editing/drawing in 3D/Render views
Round-Trip DXF -- Automatically Generate CAD Detail from 3D View
Unrestricted Positioning available while editing in 3D/Render Views
Spherical Panoramic Backdrops
Cabinets/Fixtures/Furniture
Ability to add Cabinet Hardware such as hinges and handles
Cabinet Hardware library
Ability to assign materials for doors/drawers/hardware for cabinets
Create cabinet groupings ("Architectural Blocks") and save these to library
Cabinets, Fixtures and Furniture can now be placed on any User or CAD layer
New libraries for Exterior Furniture, Exterior Fixtures, Geometric Shapes, and Millwork
Ability to apply fills/patterns for cabinets in Plan view
CAD Blocks/Details
Faster CAD Detail/Layout Generation
CAD Block management improvement including renaming
Unlimited number of lines in CAD Blocks
Ability to add nested blocks to CAD Block library
CAD Tools
Arcs/Splines with arrowheads
Unlimited number of CAD items now allowed
New CAD tools, including Move, Rotate, Resize, Reflect, Replicate, Move-To-Front,
2
Reverse Direction
Convert To/From Polyline tool added for many architectural objects (including terrain
objects, roads, and countertops)
Horizontal and Vertical 3D Polyline Solids to create 3D shapes
Multiple-Edit of different CAD Objects at the same time
Text justification tools
Dimensions
Point-to-point dimensions, Baseline dimensions
Fully editable extension lines
Improved dimension accuracy, configurable dimension rounding and inaccuracy
reporting
Aligned dimensions for off-angle walls/lines/etc.
Configurable dimensioning editing
Doors
Configurable exterior sills
Ability to add Door Hardware such as Hinges and Handles
Door Hardware Library
Import/Export
"Pack-and-Go" Entire Plan Export -- exports plan with all necessary textures, patterns,
images, etc.
DWG/DXF Import allows unit specifications
DWG/DXF Export now includes hatching/fills, fonts, text blocks, text alignment, and filled
areas
EMF File Export
JPEG, PNG Image File Load/Save
POV-Ray (.POV) Export
AVI Walkthrough movie support
XLS, HTML Material List export (version 8.0-style exporting also supported)
Editing
New "Select Same" tool allowing similar objects to be selected at the same time
New "Load Properties" tool allowing the application of object properties to other objects
Improved dialog box layouts, new shortcut tools, new shortcut keys available
New architectural object edit tools including Move, Rotate, Resize, Reflect, and
Replicate.
Ability to move and rotate an edit area
Electrical/Lights
Ability to adjust all lights in plan with new "Adjust Lights" dialog
Electrical services may include more than one light, and library lights come preconfigured
appropriately
Editable electrical connections
Expanded light specifications, including soft shadow parameters and full
3
positional/directional control
Electrical items can now have labels
Foundations/Framing
Framing items each have their own, editable material
Automatic Blocking and Bracing (linear and/or staggered) for walls, joists, and rafters
Mud Sills may be included in framing system
Platform edges can have materials applied to them
New post/beam framing specification tools
I-Joists
Layouts
Layout templates allow you to save and reuse title blocks and borders
Improved Layout Management tools, including ability to send view to any page in layout,
view port border properties
Faster Layout generation from 2D/3D views
Libraries
New categories include Fixtures (Exterior), Furnishings (Exterior), Geometric Shapes,
Hardware, Millwork, Architectural Blocks
New library items include window treatments, door hardware, new cabinet hardware,
road signs, etc. (see Content Team for this)
Dockable library browser
Library items come pre-packaged with their own materials -- user-created library items
Electrical lights come pre-packaged with appropriate lights for rendering purposes
Search Engine allows you to search for library items
Copyright information can be stored in user-created library items
Improved library browser navigation and presentation
Automatic CAD Block generation for user-created library items
Library doors can now have interior/exterior material settings
Updated and expanded libraries
Dynamic Material Defaults -- library items use the current plan's default materials as
appropriate
Unlimited number of materials can be included with any library object
Material List
New columns for equipment, unit costs, % markup, and labor requirements
Improved, customizable spreadsheet appearance, and improved material list editing
Ability to save and load material lists for editing and comparison
Improved material list Polyline tool including layer specification, editing, and filling
capability
Ability to add/delete items at any time, also ability to change order of the columns
Windows/Door "Use" tool -- determine which components in a door/window will go into
material list (good for window/door assemblies)
4
Materials
Hierarchical view for displaying object and sub-object materials
New Material settings such as reflectivity, bump-maps, and translucency for Raytracing
Raytrace Preview of materials
New Material defaults including cabinet door panels/styles, hardware, molding, and
custom countertop configurations
Full texture rotation capability
Ability to apply materials to many new types of individual objects including room
moldings, window moldings, individual walls, framing
Molding
Create moldings anywhere using Molding Line/Molding Polyline tools
Room Molding Polyline tool allows fully customizable room molding
Ability to create and edit multiple fully customizable moldings on rooms, cabinets,
countertops, doors, and windows
Plans
Ability to create a Plan Database with thumbnails for easy browsing and searching
through plans
Ability to use Plan Templates when creating a new file, allowing you to pick from several
starting points for your new plan
Railings/Stairs
Fully editable library newels and balusters may be assigned to railings or stairs
New baluster/newel specification options
Railing panels may be created between posts/newels, and stored in the library
Custom Handrail Moldings for stairs/railings
Handrails on walls next to stairs, and around corners
Brackets
Stair runners
Roofs / Gutters / Skylights
Advanced materials for roofs, gutters, fascia, ceilings, soffits, eaves, skylights
Rooms
Platform thickness separate for each room
Enhanced room dialog options
New "attic rooms" allow flexible storage areas and Cape Cod designs
Floor coverings/finishes and under layers
Room fills/patterns display in plan view
Create Room Polyline, tool
Schedules
Schedules for cabinets, fixtures, furniture, and electrical items
HVAC, plumbing schedules also available (through fixture schedules)
5
Schedule exporting to text and spreadsheet formats
Terrain/Roads/Sidewalks
Road, Road Median, Curb, Gutter, Driveway, and Sidewalk tools
Road Striping tools
Automatic sidewalk generation
Save terrain/road objects to library as Terrain Blocks
Terrain elevation regions
Terrain import wizard (DWG/DXF import)
New terrain elevation editing tools
Fence tool
Walls
Walls may be drawn at any angle
New curved wall tools including Lock Ends, and Specify Radius
Duplicate Wall Type tool
New pony wall tools, including pony wall defaults
Align groups of walls with floor above/below
Corner boards/Quoin heights fully definable, improved corner board/quoin specification
Windows
Curtains/Binds/Window Treatments may be applied to windows
Skylight frame width/height, glass, now editable
The above items are planned to be included in the Release of Chief Architect 9.0, but some may
not be included in the final release of the program.
 楼主| 发表于 2003-4-11 20:44:10 | 显示全部楼层
看它已经有光影跟踪了
发表于 2003-4-12 03:37:31 | 显示全部楼层
室内装修的二线人员岂不要下岗了?
 楼主| 发表于 2003-4-12 08:38:40 | 显示全部楼层
的确,你好象对CHIEF很熟悉,如果我是老板,只要培训几个门面的销售人员就可以马上学会了,对家庭装修这套软件已经是绰绰有余了,至于圆方在强大的CHIEF面前就象一个小丑一样了。
发表于 2003-4-13 02:23:58 | 显示全部楼层
当年Luckjim再ABBS鼓动大家学习、使用ArchiCAD的时候也把ArchiCAD捧到天上。我就心痒了,我就上贼船了,我就……后来才发现,实际上是……然后我就……反正现在还在郁闷。
一失足成千古恨啊!大家千万当心!用不上先进的软件无所谓,耽误了挣钱就罪过了。
切切!
 楼主| 发表于 2003-4-13 09:23:00 | 显示全部楼层
这小子又在说我的坏话了,我没贬AC啊,CA是室内设计领域的快枪手,根本不可能抢AC的建筑CAD市场,是提高室内设计生产力和销售的最佳帮助。
发表于 2003-4-13 16:24:35 | 显示全部楼层
chief architect 以前的弱点之一就在渲染方面,现在渲染加强了就太棒了!
发表于 2003-4-15 08:24:54 | 显示全部楼层
最初由 wolfkingforever 发布
[B]当年Luckjim再ABBS鼓动大家学习、使用ArchiCAD的时候也把ArchiCAD捧到天上。我就心痒了,我就上贼船了,我就……后来才发现,实际上是……然后我就……反正现在还在郁闷。
一失足成千古恨啊!大家千万当心!用不?.. [/B]
我也是因此而坠入泥潭,不可拔:8
发表于 2003-4-15 22:46:24 | 显示全部楼层
这条贼船还不错啊,可悉插件太不易得到, 不用插件做点复杂的东西又累。
GMT+8, 2026-11-22 10:58 , Processed in 0.826842 second(s), 27 queries , Gzip On, File On.
