查看: 589|回复: 2
[求助]:大家帮我看看,看这样能不能实现?
发表于 2005-10-27 10:17:14 | 显示全部楼层 |阅读模式
我想实现的功能就是:已知一个平面的矢量,跟很多空间曲线(AcDbCurve3d),能不能得到那些曲线跟平面相交的点的坐标?如果能的话应该怎样来实现呢?
发表于 2005-10-29 00:15:30 | 显示全部楼层
还没研究过,但肯定是有难度的
 楼主| 发表于 2005-10-29 12:29:02 | 显示全部楼层
AcGePlane::intersectWith(
const AcGeLinearEnt3d& linEnt,
AcGePoint3d& resultPnt,
const AcGeTol& tol = AcGeContext::gTol) const;
linEnt Input linear entity
resultPnt Output intersection point result
tol Input tolerance
Returns Adesk::kTrue if this plane and the linear entity linEnt are non-parallel. In this case, it also returns the intersection point in the output argument resultPnt. Intersection is performed with tolerance tol.
Returns Adesk::kFalse if there is no intersection.
这个函数可以求线性的直线跟面的交点,但是如果是曲线的话应该怎么求呢?而且AcGeLinearEnt3d这个应该怎么得到呢?
GMT+8, 2026-11-5 22:45 , Processed in 0.424216 second(s), 36 queries , Gzip On.
