查看: 2225|回复: 3
[分享]:A good LISP/DCL example for beginners
发表于 2005-10-28 09:20:21 | 显示全部楼层 |阅读模式
Main Features
   => How to use some common dcl dialog tiles and the lisp to drive them
   => How to use global and local variables with dialog boxes including an automatic variable generator
   => How to prepare dialog box defaults using global and local variables
   => How to make two clusters of radio_buttons behave as one cluster
   => How to turn tiles on and off based on user input and previous selections
   => How to close a dialog for user input and then return to the dialog
   => How to open a second dialog from the first (original code by Gary Fowler)
   => How to align list items in columns in a list_box (original method by Gary Fowler)
   => How to logically connect two toggles and the necessary lisp code
   => How to use the system registry to store dialog box screen location (original method by Gary Fowler)
   => How to use widgets in dcl like macros in lisp (original method by Gary Fowler)
   => How to pass arguments or data to lisp macros
   => How to "set" variable names and values from lists and strings
   => How to store and read data from text files
   NEW FEATURES
   => A new window has been added that shows the code associated with each dialog box
      button as you click on it.
发表于 2005-10-28 09:47:02 | 显示全部楼层
1、加载时有提示的:  错误: 语法错误
2、VL编辑器检查: ; 错误: SETQ 中变量名称错误: " ARCH#YEAR2 "
3、问题出在这里:  (setq ARCH#LOGO " About DCL Demo?)
4、修改下:  (setq ARCH#LOGO " About DCL Demo? ")
5、牛人啊。效果如图:
发表于 2005-10-28 09:48:08 | 显示全部楼层
about
发表于 2005-10-29 10:30:41 | 显示全部楼层
一个很好的Demo.
About窗口需要点击窗口下方的绿条才能关闭.
GMT+8, 2026-11-22 08:29 , Processed in 0.438204 second(s), 16 queries , Gzip On, File On.
