查看: 619|回复: 0
[下载]:当你为CAD打印发愁时,试试这个
发表于 2003-4-15 19:34:49 | 显示全部楼层 |阅读模式
Plot Minder with MS Access 97 runtime
如果你的系统上没有Access97(即使是Access95或Access2000也需要此版本)请选择这个版本的Plot Minder 。(大约20 Mb)
Plot Minder without MS Access 97 runtime
有Access97。(大约11 Mb)
NOTE: Plot Minder初始密码是pmadmin (全是小写,大小写敏感).
Note: 这是个演示版的Plot Minder. 除了会在数据区插入"DEMO"外功能没有限制。5月1日会过期。
这是简介:
Do you need to plot and track HPGL/2, TIFF, DWF, or PDF files?
Then check out RePLot which can integrate with Plot Minder to create a complete plot tracking solution!
Plot Minder 2.5 now includes a beta release which is compatible with AutoCAD 2004! This beta expires on May 1, 2003.
Tracking plot usage and costs has never been an easy or accurate thing to do. Plot Minder changes all that! Plot Minder delivers unparalleled ease of use and accuracy for capturing AutoCAD plots. Now every plot can be recorded for billing purposes and media usage. With the Plot Minder Client, AutoCAD users will hardly notice that anything is different. Valuable information such as job number, drawing name, plot area (requested or effective), user name, date & time, copies, and cost will be automatically captured. CAD administrators can now have this valuable information at their fingertips. With Plot Minder Viewer, data can be presented in just about any way a company wishes. Plot Minder comes with 13 standard reports, and an unlimited number of "filtered" reports. And if that still isn't enough, we have provided "hooks" into the plot data to allow you to produce your own custom reports. From now on, billing your clients will be painless and accurate.
Virtually transparent to the CAD user
Track billing and media usage
Standard and filtered reports
Create custom reports
Supports batch plotting
English / Metric area calculations
Automatically update the Viewer
Standard and user comments
Export data to CSV file
Password protected administrative interface
Automatically Captures & Determines:
Job Number
Drawing Name
Plot Area (requested or effective)
Plot Type (Draft, Final, etc.)
User Name
Date & Time
Copies
Cost
Limitations with AutoCAD R14:
There are some limitations with Plot Minder when running in conjunction with AutoCAD R14:
Does not automatically capture the number of copies
Cannot capture plot to file type plots
It is not compatible with the R14 Batch Plotting utility. For AutoCAD R14 users, we will include a free copy of our Batch Script Processor (a $75 value) that will allow you to capture batch plots under R14.
Pricing
  Base License: (1 user License + Reporter)  $195
  Additional seats: 2-10 $95 per seat
  (in addition to base license) 11-50 $75 per seat
    51+  $65 per seat
CAD fx - Plot Minder - AutoCAD Plot Cost Control - autocad plot tracking, autocad plot tracker, autocad
GMT+8, 2026-11-3 20:47 , Processed in 0.441713 second(s), 32 queries , Gzip On.
