查看: 1752|回复: 4
[LISP函数]:测试“相同”Pline
发表于 2005-10-30 00:07:04 | 显示全部楼层 |阅读模式
包括旋转、反向或者镜像的Pline,层、颜色等信息可以在 getinfo 中自行添加。
  1. (defun xdl-pl-sam (e1 e2 / getinfo getdis getdis_to_sp)
  2.   (defun getinfo (lst)
  3.     (vl-remove-if-not
  4.       (function
  5.         (lambda (x) (vl-position (car x) '(39 40 41 42 43)))
  6.       )
  7.       lst
  8.     )
  9.   )
  10.   (defun getdis        (e / n m dl)
  11.     (setq n (fix (vlax-curve-getendparam e))
  12.           m 0.
  13.     )
  14.     (repeat n
  15.       (setq dl (cons (vlax-curve-getdistatparam e m) dl)
  16.             m  (1+ m)
  17.       )
  18.     )
  19.     dl
  20.   )
  21.   (defun getdis_to_sp (e / sp m n dl)
  22.     (setq sp (vlax-curve-getstartpoint e)
  23.           m  1.
  24.           n  (fix (vlax-curve-getendparam e))
  25.     )
  26.     (repeat n
  27.       (setq dl (cons (distance (vlax-curve-getpointatparam e m) sp) dl)
  28.             m  (1+ m)
  29.       )
  30.     )
  31.     dl
  32.   )
  33.   (if (and (= (vlax-curve-getendparam e1) (vlax-curve-getendparam e2))
  34.            (= (vlax-curve-isclosed e1) (vlax-curve-isclosed e2))
  35.       )
  36.     (and (equal (getinfo (entget e1)) (getinfo (entget e2)) 1e-10)
  37.          (or (equal (getdis e1) (getdis e2) 1e-7)
  38.              (equal (getdis e1) (reverse (getdis e2)) 1e-7)
  39.          )
  40.          (equal (getdis_to_sp e1) (getdis_to_sp e2) 1e-7)
  41.     )
  42.   )
  43. )
 楼主| 发表于 2005-10-30 00:26:09 | 显示全部楼层
“相同” Arc
  1. (defun xdl-arc-sam (a1 a2 / l1 l2)
  2.   (setq        l1 (entget a1)
  3.         l2 (entget a2)
  4.   )
  5.   (and (equal (assoc 40 l1) (assoc 40 l2) 1e-10)
  6.        (equal (vlax-curve-getdistatparam a1 (vlax-curve-getendparam a1))
  7.               (vlax-curve-getdistatparam a2 (vlax-curve-getendparam a2))
  8.               1e-3
  9.        )
  10.   )
  11. )
发表于 2005-10-30 06:18:08 | 显示全部楼层
;对pline,对镜像的情况判断还有点问题。
;;arc判断,还可这样
  1. (defun x-samarc(e1 e2)
  2.   (and
  3.     (equal(vlax-curve-getarea e1)(vlax-curve-getarea e2)1e-4)
  4.     (equal(assoc 40(entget e1))(assoc 40(entget e2))1e-4)
  5.   )
  6. )
 楼主| 发表于 2005-10-30 08:33:48 | 显示全部楼层
测试中发现 Pline 镜像后,精度的取值是一个函数是否成功的关键
发表于 2008-5-2 15:01:45 | 显示全部楼层
旋转、缩放、镜像均可。(容差)
http://zml84.blog.sohu.com/77983032.html
GMT+8, 2026-11-22 10:32 , Processed in 0.368491 second(s), 18 queries , Gzip On, File On.
