查看: 1358|回复: 3
[求助]:门式钢架怪异的计算文件,求助各位大虾
发表于 2005-11-10 09:48:29 | 显示全部楼层 |阅读模式
钢 梁          6                截面类型= 27; 布置角度=  0;计算长度: Lx=  36.04, Ly=   3.00    构件长度=   6.01;  计算长度系数: Ux=   6.00    Uy=   0.50    变截面 H 形截面 H:  B1=   300, B2=   300, H1=1100, H2=   700 T1=    14 T2=  18 T3=  18    轴压截面分类:X轴:b类, Y轴:c类         组合号     M        N        V        M        N        V            1     958.49    52.89   186.84   -21.63   -48.44  -125.05            2     731.92    39.23   143.05   -13.61   -35.53   -96.09            3    1065.54    52.47   207.05   -35.85   -48.02  -135.75            4     838.97    38.82   163.26   -27.82   -35.11  -106.79            5    1871.94    90.55   348.98   143.25   -84.71  -211.38            6    1645.36    76.90   305.18   151.28   -71.80  -182.42            7    1888.12    98.21   355.96    79.81   -92.23  -221.83            8    1243.10    98.79   251.07  -263.67   -94.48  -185.53            9    1016.53    85.14   207.28  -255.64   -81.56  -156.57           10    1447.94   103.98   287.42  -205.04   -99.06  -203.73           11    1631.36    73.13   303.42   159.17   -67.29  -182.14           12    1404.79    59.47   259.63   167.19   -54.37  -153.17           13    1695.59    72.88   315.55   150.64   -67.04  -188.56           14    1469.02    59.22   271.76   158.66   -54.12  -159.59           15    1002.53    81.37   205.52  -247.75   -77.05  -156.29           16     775.95    67.71   161.73  -239.72   -64.14  -127.32           17    1066.76    81.12   217.65  -256.28   -76.80  -162.71           18     840.18    67.46   173.86  -248.25   -63.89  -133.74           19    1317.23    58.92   247.19   112.35   -53.50  -151.37           20    1090.66    45.27   203.40   120.38   -40.59  -122.40           21    1424.29    58.51   267.40    98.14   -53.08  -162.06           22    1197.71    44.85   223.61   106.17   -40.17  -133.10           23     877.05    64.69   178.66  -172.49   -60.33  -133.27           24     650.47    51.04   134.87  -164.46   -47.42  -104.31           25     984.10    64.27   198.87  -186.70   -59.92  -143.97           26     757.53    50.62   155.08  -178.67   -47.00  -115.00           27    1616.35    83.58   301.82    58.43   -82.62  -187.79           28    1353.17    69.31   251.87    52.78   -69.19  -156.14           29    1272.32    91.20   255.64  -165.08   -82.73  -180.94           30    1054.06    76.34   212.68  -141.66   -68.60  -151.13           31    1268.98    98.90   274.60    37.75   -93.19  -160.43           32    1042.40    85.24   230.81    45.77   -80.28  -131.47           33    1466.05   104.05   303.89     5.95   -98.16  -186.16           34    1846.06    90.45   325.45  -158.16   -86.00  -236.48           35    1619.48    76.79   281.66  -150.14   -73.08  -207.52           36    1870.01    98.13   339.49  -131.18   -93.13  -239.40           37    1028.41    81.47   229.05    53.66   -75.76  -131.19           38     801.83    67.82   185.26    61.69   -62.85  -102.22           39    1092.64    81.22   241.18    45.13   -75.51  -137.61           40     866.06    67.57   197.38    53.16   -62.60  -108.64           41    1605.48    73.02   279.90  -142.25   -68.57  -207.24           42    1378.91    59.37   236.11  -134.22   -55.66  -178.27           43    1669.71    72.77   292.02  -150.78   -68.32  -213.66           44    1443.14    59.12   248.23  -142.75   -55.41  -184.69           45     895.16    64.77   195.13    38.50   -59.43  -115.70           46     668.59    51.11   151.34    46.53   -46.52   -86.74           47    1002.22    64.35   215.34    24.29   -59.02  -126.40           48     775.64    50.69   171.55    32.31   -46.10   -97.43           49    1299.12    58.85   230.72   -98.63   -54.40  -168.94           50    1072.54    45.19   186.93   -90.61   -41.49  -139.97           51    1406.17    58.43   250.93  -112.85   -53.98  -179.63           52    1179.60    44.78   207.14  -104.82   -41.07  -150.67           53    1283.41    91.25   265.72    13.21   -86.26  -165.95           54    1063.30    76.38   221.08    15.10   -72.22  -137.94           55    1605.26    83.54   291.74  -119.86   -79.09  -202.77           56    1343.93    69.28   243.47  -103.98   -65.57  -169.33                              --- 梁的弯矩包络 ---  梁下部受拉:     截面     1        2        3        4        5        6        7     弯矩     0.00     0.00     0.00     0.00     0.00     0.00  -167.19  梁上部受拉:     截面     1        2        3        4        5        6        7     弯矩  1888.12  1538.45  1224.04   935.30   661.41   402.36   263.67  考虑屈曲后强度强度计算应力比 = 0.874  抗剪强度计算应力比 =  0.161  平面外稳定最大应力(N/mm*mm) =    234.53  平面外稳定计算最大应力比 =  0.795  考虑屈曲后强度计算应力比 = 0.874 < 1.0  抗剪强度计算应力比 = 0.161 < 1.0  平面外稳定最大应力 < f=    295.00  腹板高厚比 H0/TW=  61.71 > [H0/TW]=  56.45 *****   (注:腹板高度变化=  66.6mm/m > 60 mm/m, 按不考虑受剪板幅屈曲后强度控制)  翼缘宽厚比  B/T =   7.94 <  [B/T] =   12.38                            --- (恒+活)梁的相对挠度 (mm) ---     截面     1        2        3        4        5        6        7   挠度值     0.00     0.76     2.57     5.30     8.81    12.88    17.25  最大挠度值 =   17.25         最大挠度/梁跨度 =  1/       1045.  斜梁坡度初始值:  1/    20.00  变形后斜梁坡度最小值:  1/    26.47  变形后斜梁坡度改变率 = 0.244  <  1/3  构件重量 (Kg)=    1079.75
其中腹板高厚比 H0/TW=  61.71 > [H0/TW]=  56.45 *****  (注:腹板高度变化=  66.6mm/m > 60 mm/m, 按不考虑受剪板幅屈曲后强度控制)  是什么意识,此梁在中间摇摆柱的地方,为什么腹板高厚控制这么严格,我应该怎么调整
发表于 2005-11-10 11:01:02 | 显示全部楼层
拜托,把计算文件发上来,这个怎么看?
 楼主| 发表于 2005-11-10 12:08:43 | 显示全部楼层
这就是从计算文件里面那过来的梁的计算文件呀
发表于 2005-11-10 13:54:52 | 显示全部楼层
高厚比超限加腋,根据高厚比的计算算一下。你给的东西太局部。。
GMT+8, 2026-11-3 00:52 , Processed in 0.475183 second(s), 37 queries , Gzip On.
