查看: 914|回复: 1
[求助] [求助]:怎么也解决不了,请帮帮忙,谢谢!
发表于 2005-11-11 08:40:21 | 显示全部楼层 |阅读模式
gcljs.mnu代码如下:
***MENUGROUP=GcGroup
***POP12
**GcMenu
[Gcljs(&G)]
[直线(&L)...]^C^C_Line
加载后我用(menucmd "P15=+GcGroup.GcMenu")语句显示不了该菜单
请问要怎样才能用menucmd 函数把该菜单加到CAD中“帮助”菜单之后?
请帮帮忙,谢谢!
已领礼包: 9341个
发表于 2005-11-11 11:08:51 | 显示全部楼层
Kevin Nehls
Mar 8 2002, 6:09 am   show options
Newsgroups: autodesk.autocad.customization
From: "Kevin Nehls" <kevinn at safeworks dot com> - Find messages by this author
Date: Thu, 7 Mar 2002 13:55:05 -0800
Local: Fri, Mar 8 2002 5:55 am
Subject: Re: partial menu help
Reply to Author | Forward | Print | Individual Message | Show original | Report Abuse
Well, FWIW this is what I use on our network to reload our
menu.  I've just replaced our menugroup and mns filenames to
something more generic.  You may also have to replace the
pop# parts with whatever you use for your menu labels.
(defun LOADMENU ()
  (if (menugroup "<your_menugroup_name_here>")
    (command "menuunload" "<your_menugroup_name_here>")
  (if (findfile "your_menu_filename_here.mns")
    (progn
      (command "menuload" "your_menu_filename_here.mns")
      (menucmd
"Gacad.window=+your_menugroup_name_here.pop1")
      (menucmd
"Gacad.window=+your_menugroup_name_here.pop2")
      (menucmd
"Gacad.window=+your_menugroup_name_here.pop3")
      (menucmd
"Gacad.window=+your_menugroup_name_here.pop4")
      (menucmd
"Gacad.window=+your_menugroup_name_here.pop5")
    (alert
      "Cannot find YOUR MENU file.\nCheck your support
paths."
  (princ)
HTH
Kevin Nehls
GMT+8, 2026-11-4 17:50 , Processed in 0.483671 second(s), 34 queries , Gzip On.
