查看: 619|回复: 3
[求助]:为什么同学录总是上不去,请管理员帮助解决一下。
发表于 2005-11-15 06:54:30 | 显示全部楼层 |阅读模式
为什么同学录总是上不去,请管理员帮助解决一下。总是显示错误。
发表于 2005-11-17 17:14:34 | 显示全部楼层
如果不是内网问题,请多刷新几次。
 楼主| 发表于 2005-11-18 06:48:01 | 显示全部楼层
刷新问题依然存在。显示:
Database error in vBulletin 2.2.1:
Invalid SQL: select sum(schoolnums) as schoolnums,sum(classnums) as classnums from
mysql error: You have an error in your SQL syntax.  Check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
mysql error number: 1064
Date: Friday 18th of November 2005 06:46:57 AM
Script: http://www.xdcad.net/forum/school/index.php?
Referer:
发表于 2005-11-18 09:37:35 | 显示全部楼层
是上不去了,有错误,你等几天再试试
GMT+8, 2026-11-3 02:24 , Processed in 0.430981 second(s), 30 queries , Gzip On.
