查看: 1844|回复: 1
[ARX程序]:复制布局命令
发表于 2005-11-21 21:48:15 | 显示全部楼层 |阅读模式
实现快速复制另外一张图的所有布局。特别用于视口分好一张图,其他图直接复制视口,不用安装专业软件再分了。
void TOMcplayout()
        char pSrcFile[255];
        char* lyName;
        const char* filea = "myfile.dwg";
        struct  resbuf *result = acutNewRb(RTSTR);
        if (acedGetFileNavDialog("选择",filea, "dwg;eps;abc",NULL, 33, &result)!=RTNORM)
                return;
        strcpy(pSrcFile,result->resval.rstring);
        acutRelRb(result);
        char buf[10];
        bool bCopyModel;
        if (acedGetString(1,"复制模型空间实体<n>:",buf)!=RTNORM)
                return;
        if (buf[0]==0 || buf[0]=='n' || buf[0]=='N')
                bCopyModel=FALSE;
        else
                bCopyModel=TRUE;
        //acedGetString(0,"源文件名:",pSrcFile);
        Acad::ErrorStatus mEs;
        AcDbDatabase *pDWTdb = new AcDbDatabase(false);
        if (Acad::eOk == pDWTdb->readDwgFile(pSrcFile))
                //get the layout dictionary
                AcDbDictionary *pDict = NULL;
                pDWTdb->getLayoutDictionary(pDict,AcDb::kForRead);
                AcDbObject *pObj = NULL;
                AcDbLayout *pSrcLayout = NULL;
                AcDbLayout *pNewLayout = NULL;
                AcApLayoutManager *pLayoutMan = (AcApLayoutManager*)acdbHostApplicationServices()->layoutManager();
                AcDbObjectId pLayoutID,pBTRId;
                AcDbDictionaryIterator *pDicItr=pDict->newIterator(AcRx::kDictSorted);
                for(;!pDicItr->done();pDicItr->next())
                        mEs=pDicItr->getObject(pObj,AcDb::kForRead);
                        if(mEs == Acad::eOk)
                                pSrcLayout=AcDbLayout::cast(pObj);
                                pSrcLayout->getLayoutName(lyName);
                                if (!bCopyModel && stricmp(lyName,"Model")==0)
                                        continue;
                                pNewLayout=0;
                                pNewLayout=pLayoutMan->findLayoutNamed(lyName,TRUE);
                                if (!pNewLayout)
                                        pLayoutMan->createLayout(lyName,pLayoutID,pBTRId);
                                        mEs=acdbOpenObject(pNewLayout,pLayoutID,AcDb::kForWrite);
                                copyLayout(pNewLayout,pSrcLayout,pDWTdb);
                                pNewLayout->close();
                                pSrcLayout->close();
                delete pDicItr;
                pDict->close();
                pLayoutMan->updateLayoutTabs();
        delete pDWTdb;
void copyLayout(AcDbLayout*pNewLayout, AcDbLayout* pSrcLayout,AcDbDatabase* pSrcDoc)
        pNewLayout->copyFrom(pSrcLayout);
        //copy entitys from source layout
        AcDbObjectId sourceId = pSrcLayout->getBlockTableRecordId();
        AcDbObjectId newBtrId = pNewLayout->getBlockTableRecordId();
        // Source BlockTableRecord
        AcDbBlockTableRecord *pSource = 0,*pNewBTR=0;
        // Open Source for Read
        AcDbIdMapping idMap;
        Acad::ErrorStatus es = acdbOpenObject(pSource, sourceId, AcDb::kForRead);
        if(es == Acad::eOk)
                //es=acdbOpenObject(pNewBTR,newBtrId,AcDb::kForWrite);
                if (es==Acad::eOk)
                        AcDbBlockTableRecordIterator* pIter = 0;
                        pSource->newIterator(pIter);
                        AcDbObjectIdArray Idlist;
                        while(!pIter->done())
                                // Add all the entities to the list
                                AcDbEntity *pEnt = 0;
                                es = pIter->getEntity(pEnt, AcDb::kForRead);
                                if(es == Acad::eOk)
                                        AcDbObjectId obj;
                                        AcDbObjectId id = pEnt->objectId();
                                        Idlist.append( id );
                                        if((obj = pEnt->extensionDictionary()) != AcDbObjectId::kNull)
                                                AcDbDictionary *pDict = 0;
                                                acdbOpenObject(pDict, obj, AcDb::kForWrite);
                                                pDict->setTreatElementsAsHard(Adesk::kTrue);
                                                pDict->close();
                                        pEnt->close();
                                pIter->step();
                        delete pIter;
                        pSrcDoc->wblockCloneObjects(Idlist,newBtrId,idMap,AcDb::kDrcReplace,false);
                        //pNewBTR->close();
                pSource->close();
发表于 2008-7-11 16:01:36 | 显示全部楼层
编译没有问题:)
GMT+8, 2026-11-22 08:14 , Processed in 0.549542 second(s), 12 queries , Gzip On, File On.
