楼主: tctabc
[1201]怎样编写一个梯形的面积计算列式呢?
已领礼包: 2个
发表于 2005-12-3 07:11:24 | 显示全部楼层
我測試怎麽沒發現問題呢?
二位老兄,將源碼貼出來吧!
確實有問題,修改了一下:
[PHP](defun c:test (/ h  l1 l2 mj        polygon        pt1 pt2        pt3 pt4        ptlist
               str)
  (setq ptlist (vertexs (car (setq polygon (entsel "\n請點選梯形:")))))
  ;|(setq        ptlist
         (massoc 10
                 (entget (car (setq polygon (entsel "\n請點選梯形:"))))
  (setq mj (vlax-curve-getarea (car polygon)))
  (setq        pt1 (nth 0 ptlist)
        pt2 (nth 1 ptlist)
        pt3 (nth 2 ptlist)
        pt4 (nth 3 ptlist)
  (if (inters
        pt1 pt2        pt3 pt4        nil)
    (if        (inters
          pt1 pt3 pt2 pt4 nil)
      (setq l1 (max
                 (distance pt1 pt4)
                 (distance pt2 pt3)
            l2 (min
                 (distance pt1 pt4)
                 (distance pt2 pt3)
    (setq l1 (max
               (distance pt1 pt2)
               (distance pt3 pt4)
          l2 (min
               (distance pt1 pt2)
               (distance pt3 pt4)
  (setq h (/ (* mj 2) (+ l1 l2)))
  (setq        str (strcat "L1="
                    (rtos l1)
                    "&L2="
                    (rtos l2)
                    "&H="
                    (rtos h)
                    "&S=("
                    (rtos l1)
                    (rtos l2)
                    (rtos h)
                    "/2="
                    (rtos mj)
  (command "TEXT" "J" "C" (GE_CENTROID ptlist) "" "" str)
  (princ)
)[/PHP]
獲取頂點函數
[PHP](defun vertexs (ename / plist pp n)
  (setq obj (vlax-ename->vla-object ename))
  (setq        plist (vlax-safearray->list
                (vlax-variant-value
                  (vla-get-coordinates obj)
  (setq n 0)
  (repeat (/ (length plist) 2)
    (setq pp (append
               pp
               (list (list (nth n plist) (nth (1+ n) plist)))
    (setq n (+ n 2))
  pp
)[/PHP]
老外寫的質心函數
[PHP];; ******************************************************************************
;; GE_centroid
;; Determine centroid of a polygon
;; Algorithm:
;; 1. Form trapezoids by dropping lines from each segment to a basey axis.
;; 2. Calculate the area and CG of the triangle and rectangle in each trapezoid
;; 3. Sums up weighted moments against given axes in X and Y direction
;;    (may use x and y axes if number is small)
;; 4. Derived CG by dividing weighted sum by total area.
;; ! (C) 1999-2004, Four Dimension Technologies, Bangalore
;; ! e-mail   : rakesh.rao@4d-technologies.com
;; ! Web      : www.4d-technologies.com
(defun GE_centroid (vlist  /          segno         n        ttl_area      basex
                    basey  p1          p2         x1        x2     y1     y2
                    t_x           t_y          t_area t_xm        t_ym   r_x    r_y
                    r_area r_xm          r_ym         Mx        My
  (setq
    vlist    (append vlist (list (car vlist)))
    segno    (1- (length vlist))        ; no of segments
    n             0
    Ttl_Area 0.0                        ; total area
    Mx             0.0                        ; Sum of moment to basex line
    My             0.0                        ; Sum of moment to basey line
    basex    (car (nth 0 vlist))        ; arbitrary axes (will reduce error for large numbers)
    basey    (cadr (nth 0 vlist))
  (repeat segno
    (setq
      p1       (nth n vlist)                ; process current segment
      p2       (nth (1+ n) vlist)
      x1       (car p1)
      y1       (cadr p1)
      x2       (car p2)
      y2       (cadr p2)
                                        ; For the triangle
      t_x      (- (* (+ x2 x2 x1) 0.333333) basex) ; cg of trianlge
      t_y      (- (* (+ y1 y1 y2) 0.333333) basey)
      t_area   (* (- y2 y1) (- x2 x1) 0.5) ; area of triangle
      t_xm     (* t_area t_x)                ; moment to Basex
      t_ym     (* t_area t_y)                ; moment to basey
                                        ; For the rectangle
      r_x      (- (/ (+ x1 x2) 2) basex) ; CG of rectangle
      r_y      (- (/ (+ basey y1) 2) basey)
      r_area   (* (- x2 x1) (- y1 basey)) ; area of rectangle
      r_xm     (* r_area r_x)                ; moment to basex
      r_ym     (* r_area r_y)                ; moment to basey
      Ttl_Area (+ Ttl_Area t_area r_area)
      Mx       (+ Mx t_xm r_xm)                ; adds up moments to basex
      My       (+ My t_ym r_ym)                ; adds up moments to basey
      n               (1+ n)
  (list        (+ (/ Mx Ttl_Area) basex)
        (+ (/ My Ttl_Area) basey)
        0.0
[/PHP]
測試結果如圖:(還是有問題,等會再改)
发表于 2005-12-3 09:53:29 | 显示全部楼层
最初由 狂刀 发布
[B]xyp,我测试怎么老说不是梯形呢?
发一个自己写的,
支持多点梯形多义线,
支持多义线起点任意位置.
自动识别梯形
支持预选
可指定文字标注位置.
命令:txbz [/B]
测试狂刀的程序:
  1. [FONT=courier new]
  2. 命令:
  3. 命令: (LOAD "F:/BLOCK/LSP/txbz-狂刀.VLX") nil
  4. 命令: txbz
  5. 选择梯形:
  6. 选择对象:
  7. 绘图比例<1:>: 1: ; 错误: 参数类型错误: numberp: nil
  8. [/FONT]
复制代码
加载程序时最好能直接显示程序执行的命令,时间长了就忘了。
“参数类型错误”是否因为“绘图比例的设置”没有放到程序前面作判断?
偶的程序已作修改,是CAD本身计算误差的BUG。
发表于 2005-12-3 10:26:30 | 显示全部楼层
最初由 taner 发布
[B]我測試怎麽沒發現問題呢?
二位老兄,將源碼貼出來吧!
確實有問題,修改了一下:
[/B]
问题:
1、只支持四点纯粹梯形。
2、未作梯形真伪判断,非梯形也标注,三角形出错。
taner程序修改(只支持4点梯形):
  2. (defun c:test (/ h l1 l2 mj polygon pt1 pt2 pt3 pt4 ptlist str)
  3.   (setq        ptlist (vertexs (car (setq polygon (entsel "\n請點選梯形:"))))
  4.         mj     (vlax-curve-getarea (car polygon))
  5.         pt1    (nth 0 ptlist)
  6.         pt2    (nth 1 ptlist)
  7.         pt3    (nth 2 ptlist)
  8.         pt4    (nth 3 ptlist)
  9.   )
  10.   ;;判断是否平行
  11.   (if (inters pt1 pt2 pt3 pt4 nil)
  12.     (if        (not (inters pt1 pt3 pt2 pt4 nil))
  13.       (setq l1 (max (distance pt1 pt4)
  14.                     (distance pt2 pt3)
  15.                )
  16.             l2 (min (distance pt1 pt4)
  17.                     (distance pt2 pt3)
  18.                )
  19.       )
  20.     )
  21.     (setq l1 (max
  22.                (distance pt1 pt2)
  23.                (distance pt3 pt4)
  24.              )
  25.           l2 (min
  26.                (distance pt1 pt2)
  27.                (distance pt3 pt4)
  28.              )
  29.     )
  30.   )
  31.   (if (and l1 l2)
  32.     (progn
  33.       (setq h        (/ (* mj 2) (+ l1 l2))
  34.             str        (strcat        "L1="
  35.                         (rtos l1)
  36.                         "&L2="
  37.                         (rtos l2)
  38.                         "&H="
  39.                         (rtos h)
  40.                         "&S=("
  41.                         (rtos l1)
  42.                         "+"
  43.                         (rtos l2)
  44.                         ")*"
  45.                         (rtos h)
  46.                         "/2="
  47.                         (rtos mj)
  48.                 )
  49.       )
  50.       (command "TEXT"
  51.                "J"
  52.                "C"
  53.                (inters pt1 pt2 pt3 pt4 nil)
  54.                ""
  55.                ""
  56.                str
  57.       )
  58.     )
  59.     (princ "\n非梯形!")
  60.   )
  61.   (princ)
  62. )
  63. ;;;獲取頂點函數
  64. (defun vertexs (ename / plist pp n)
  65.   (setq obj (vlax-ename->vla-object ename))
  66.   (setq        plist (vlax-safearray->list
  67.                 (vlax-variant-value
  68.                   (vla-get-coordinates obj)
  69.                 )
  70.               )
  71.   )
  72.   (setq n 0)
  73.   (repeat (/ (length plist) 2)
  74.     (setq pp (append
  75.                pp
  76.                (list (list (nth n plist) (nth (1+ n) plist)))
  77.              )
  78.     )
  79.     (setq n (+ n 2))
  80.   )
  81.   pp
  82. )[/FONT]
思路:
[php]
1、选择(支持多选)多段线(*POLYLINE)判断是否闭合或首尾相连,是→继续。
2、取其顶点集,删除直线段上的所有顶点,如果首尾相连则删除首尾中的一个点,判断最后顶点数是否为4,是→继续。
3、判断剩余4点中是否存在平行线,是→继续。
4、计算平行线的长度、梯形高度、面积公式→完成标注。
[/php]
已领礼包: 2个
发表于 2005-12-3 11:29:49 | 显示全部楼层
再修改:
獲取頂點函數VERTEXS見前貼.
[PHP]
(defun c:test
       (/ h mj interpoint l1 l2 polygon pt1 pt2 pt3 pt4 ptlist str)
        pt2 (nth 1 ptlist)
        pt3 (nth 2 ptlist)
        pt4 (nth 3 ptlist)
  (if (inters
    (princ "\n相交")
    (progn (setq l1 (max
                      (distance pt1 pt2)
                      (distance pt3 pt4)
                 l2 (min
                      (distance pt1 pt2)
                      (distance pt3 pt4)
           (if (setq interspoint (inters pt1 pt4 pt2 pt3 t))
             interspoint
             (setq interspoint (inters pt1 pt3 pt2 pt4 t))
  (if (inters
    (princ "\n相交")
                      (distance pt1 pt3)
                      (distance pt2 pt4)
                 l2 (min
                      (distance pt1 pt3)
                      (distance pt2 pt4)
           (if (setq interspoint (inters pt1 pt2 pt3 pt4 t))
             interspoint
  (if (inters
        pt1 pt4        pt2 pt3        nil)
    (princ "\n相交")
                      (distance pt1 pt4)
                      (distance pt2 pt3)
                 l2 (min
                      (distance pt1 pt4)
                      (distance pt2 pt3)
             interspoint
  (if (and l1 l2)
    (progn (setq h (/ (* mj 2) (+ l1 l2)))
                             (rtos l1)
                             "&L2="
                             (rtos l2)
                             "&H="
                             (rtos h)
                             "&S=("
                             (rtos l1)
                             (rtos l2)
                             (rtos h)
                             "/2="
                             (rtos mj)
           (command "TEXT" "J" "C" interspoint "" "" str)
  (princ)
[/PHP]
文本的中心點在梯形的對角線交點上.
发表于 2005-12-3 16:55:16 | 显示全部楼层
最初由 taner 发布
[B]再修改:
獲取頂點函數VERTEXS見前貼.
(defun c:test
  (setq ptlist (vertexs (car (setq polygon (entsel "\n請點選梯形:")))... [/B]
请用一楼的DWG文件测试,如果运行成功就差不多了!
发表于 2005-12-3 17:28:55 | 显示全部楼层
xyp1964版主及taner兄
真是厉害的高手,但想在要求一下是否可以将各线段长度都标上去呢
如8楼的图片但要四边的长度有显示出来~
另外小弟用过 taner 兄的版本,想请教一下是否物件要先封闭程聚合线呢,如果是这样为何不能
先制做封闭聚合线呢?还是说程序中的判断是将各线段的线长及顶点做平行及大小判断
再延伸至面积计算
因为程度差很多不知道观念对吗
发表于 2005-12-3 19:13:23 | 显示全部楼层
只标线长就简单多了:
发表于 2005-12-3 20:03:14 | 显示全部楼层
版主您提供的这程式
可以换成繁体的吗
我系统跑出来的都是乱码
另外这程序还要搭配您自行开发的 xyp_lib.VLX 程序吗?
发表于 2005-12-3 20:36:52 | 显示全部楼层
最初由 xyp1964 发布
[B][QUOTE]最初由 狂刀 发布
发一个自己写的,
支持多点梯形多义线,
支持多义线起点任意位置.
自动识别梯形
支持预选
可指定文字标注位置.
命令:txbz [/B][/... [/B]
忘了设初值了,第一次执行输入比例(整数)不直接回车即可
已领礼包: 2个
发表于 2005-12-3 21:00:09 | 显示全部楼层
最初由 xyz518mm 发布
[B]xyp1964版主及taner兄
如8楼的图片但要四边的长度有显示出来~
另外小弟用过 taner 兄的版本,想请教一下是否物件要先封闭程聚合线呢,如果是这样为何... [/B]
小弟也正在學習中!XYP和狂刀才是真正的高手!
如果是line線,需要先聚合成多義線.我的這個程序還不能算程序.還不能解決XYP版主貼的附件中的問題.正在思考中!
发表于 2005-12-3 23:53:08 | 显示全部楼层
参考程序:
  1. [FONT=courier new];;;txbz(梯形标注)
  2. (defun c:txbz ()
  3.   (CMDLASC0)
  4.   (setq        ss (ssget '((0 . "*POLYLINE")))
  5.         i  -1
  6.   )
  7.   (while (setq s1 (ssname ss (setq i (1+ i))))
  8.     (if        (or (= (xyp-get-DXF 70 s1) 1)
  9.             (equal (xyp-get-CurveEndPoint s1)
  10.                    (xyp-get-CurveStartPoint s1)
  11.             )
  12.         )
  13.       (progn
  14.         (setq ptn (xyp-get-Vertexs s1 3))
  15.         (if (= (length ptn) 4)
  16.           (progn
  17.             (setq pt0  (nth 0 ptn)
  18.                   pt1  (nth 1 ptn)
  19.                   pt2  (nth 2 ptn)
  20.                   pt3  (nth 3 ptn)
  21.                   pt28 (xyp-get-MinMaxPoint s1 2)
  22.                   aa   (vla-get-Area (vla-obj s1))
  23.             )
  24.             (cond ((not (inters pt0 pt1 pt2 pt3 nil))
  25.                    (setq l1 (distance pt0 pt1)
  26.                          l2 (distance pt3 pt2)
  27.                    )
  28.                    (mkla "尺寸标注" 4)
  29.                    (subtxt pt0 pt1)
  30.                    (subtxt pt1 pt2)
  31.                    (subtxt pt2 pt3)
  32.                    (subtxt pt3 pt0)
  33.                    (setq pt01 (polar pt0 (+ (angle pt0 pt1) (* pi 0.5)) 1000)
  34.                          pt02 (inters pt0 pt01 pt2 pt3 nil)
  35.                          h    (distance pt0 pt02)
  36.                    )
  37.                    (subtxt pt0 pt02)
  38.                    (setq txt1 (/ (* (+ l1 l2) h) 2.0)
  39.                          txt2 (strcat "S "
  40.                                       (rtos txt1 2 3)
  41.                                       " = "
  42.                                       "("
  43.                                       (rtos l1 2 3)
  44.                                       "+"
  45.                                       (rtos l2 2 3)
  46.                                       ")"
  47.                                       "×"
  48.                                       (rtos h 2 3)
  49.                                       "/"
  50.                                       (itoa 2)
  51.                               )
  52.                    )
  53.                    (xyp-Text 8 pt28 txt2)
  54.                    (mkla "辅助线" 1)
  55.                    (command "line" pt0 pt02 "")
  56.                   )
  57.                   ((not (inters pt0 pt3 pt1 pt2 nil))
  58.                    (setq l1 (distance pt0 pt3)
  59.                          l2 (distance pt1 pt2)
  60.                    )
  61.                    (mkla "尺寸标注" 4)
  62.                    (subtxt pt0 pt1)
  63.                    (subtxt pt1 pt2)
  64.                    (subtxt pt2 pt3)
  65.                    (subtxt pt3 pt0)
  66.                    (setq pt01 (polar pt0 (+ (angle pt0 pt3) (* pi 0.5)) 1000)
  67.                          pt02 (inters pt0 pt01 pt1 pt2 nil)
  68.                          h    (distance pt0 pt02)
  69.                    )
  70.                    (subtxt pt0 pt02)
  71.                    (setq txt1 (/ (* (+ l1 l2) h) 2.0)
  72.                          txt2 (strcat "S "
  73.                                       (rtos txt1 2 3)
  74.                                       " = "
  75.                                       "("
  76.                                       (rtos l1 2 3)
  77.                                       "+"
  78.                                       (rtos l2 2 3)
  79.                                       ")"
  80.                                       "×"
  81.                                       (rtos h 2 3)
  82.                                       "/"
  83.                                       (itoa 2)
  84.                               )
  85.                    )
  86.                    (xyp-Text 8 pt28 txt2)
  87.                    (mkla "辅助线" 1)
  88.                    (command "line" pt0 pt02 "")
  89.                   )
  90.                   (t (princ "\n非梯形!"))
  91.             )
  92.           )
  93.           (princ "\n非梯形!")
  94.         )
  95.       )
  96.       (princ "\n多段线不闭合!")
  97.     )
  98.   )
  99.   (CMDLA1)
  100. )
  101. (defun subtxt (Point1 Point2 / ang)
  102.   (setq ang (rad2ang (angle Point1 Point2)))
  103.   (while (> ang 90)
  104.     (setq ang (- ang 180))
  105.   )
  106.   (command "text"
  107.            "j"
  108.            "BC"
  109.            (xyp-get-RightPoint Point1 Point2 (* sc 100))
  110.            (* sc 300)
  111.            ang
  112.            (rtos (distance Point1 Point2) 2 3)
  113.   )
  114. )
  115. (pxyp "txbz  (梯形标注)")[/FONT]
发表于 2005-12-3 23:57:56 | 显示全部楼层
效果
发表于 2005-12-4 11:30:42 | 显示全部楼层
建议把多点的梯形自动改成4顶点的多义线
已领礼包: 2个
发表于 2005-12-4 11:57:02 | 显示全部楼层
最初由 狂刀 发布
[B]建议把多点的梯形自动改成4顶点的多义线 [/B]
支持!我的想法正是這樣,先將梯形轉化爲4頂點的梯形.後面的步驟前面都談過了.
发表于 2005-12-4 14:15:02 | 显示全部楼层
首先要判断是否四边形:
(= (length (xyp-get-Vertexs ename 3)) 4)
GMT+8, 2026-11-6 20:44 , Processed in 0.704488 second(s), 54 queries , Gzip On.
