查看: 955|回复: 1
[求助]:看看我的小工具集合面板
发表于 2005-12-3 10:56:41 | 显示全部楼层 |阅读模式
请教高手,不知如何设置把"取消"按钮放置在面板的左下角.
先谢谢了!
程序代码:
//ld.dcl
ld:dialog{label="浪刀工具";
:row{
:boxed_column{
label="轴网标注";
:button{label="直线轴网";key="bb1";}
:button{label="弧线轴网";key="bb2";}
:button{label="轴网标注";key="bb3";}
:boxed_column{
label="其它";
:button{label="比例缩放";key="bb4";}
:button{label="引出线";key="bb5";}
:button{label="轴网标注";key="bb6";}
spacer_1;
cancel_button;
对话框驱动
;;;ld.lsp
(defun c:tt()
(setvar "cmdecho" 0)
(dcl_ld)
(prin1)
(defun dcl_ld()
(setq dcl_id (load_dialog "ld"))
(new_dialog "ld" dcl_id)
(action_tile "bb1" "(done_dialog 1)")
(action_tile "bb2" "(done_dialog 2)")
(action_tile "bb3" "(done_dialog 3)")
(action_tile "bb4" "(done_dialog 4)")
(action_tile "bb5" "(done_dialog 5)")
(setq dd (start_dialog))
(cond ((= dd 1)(c:NetBee_RectAxis))
((= dd 2)(c:NetBee_ArcAxis))
((= dd 3)(c:NetBee_DimAxis2p))
((= dd 4)(c:scc))
((= dd 5)(c:CHdim0))
(unload_dialog dcl_id)
(princ)
已领礼包: 593个
发表于 2005-12-3 12:22:13 | 显示全部楼层
  1. ld: dialog {
  2. label = "浪刀工具";
  3. : row {
  4.   : boxed_column {
  5.     label = "轴网标注";
  6.     : button {
  7.       label = "直线轴网";
  8.       key = "bb1";
  9.       }
  10.     : button {
  11.       label = "弧线轴网";
  12.       key = "bb2";
  13.       }
  14.     : button {
  15.       label = "轴网标注";
  16.       key = "bb3";
  17.       }
  18.     }
  19.   : boxed_column {
  20.     label = "其它";
  21.     : button {
  22.       label="比例缩放";
  23.       key="bb4";
  24.     }
  25.     : button{
  26.       label = "引出线";
  27.       key = "bb5";
  28.     }
  29.     : button {
  30.       label = "轴网标注";
  31.       key = "bb6";
  32.       }
  33.     }
  34. : column {
  35.    spacer_1;
  36.    cancel_button;
  37.     }
  38.   }
  39. }
GMT+8, 2026-11-4 03:39 , Processed in 0.448966 second(s), 35 queries , Gzip On.
