查看: 1421|回复: 9
[分享]:发现微软两个bug!
发表于 2005-12-5 16:06:38 | 显示全部楼层 |阅读模式
1, 请新建一个word文件,并在里面输入:
  =rand(200,99)
  然后回车看看会发生什么?
  据说,连比尔蓋茨都不知道为什么会这样?
2,  谁能在win2k/xp任何目录下建立一个叫aux的文件夹?
这可是某个网站的大奖赛啊,如果有谁能第一个在微软操作系统WIN2000、或者是WINXP中的任何一个目录下建立一个名字叫做aux的文件,谁就能获得1xxxx美元的奖金,呵呵!
  大家还不赶快试试啊,这可是大奖啊!!!
  做了没有啊,没有快去试试啊!
  怎么样?能行吗?反正笔者是不行,看来与大奖无缘了,你的运气如何呢?
 哈哈,看来这又是WIN2000/WINXP的一个大BUG了,呵呵!!
(再试试con, nul 都不行)
发表于 2005-12-5 16:51:12 | 显示全部楼层
看看:
发表于 2005-12-5 17:58:55 | 显示全部楼层
第一个应该是个彩蛋吧?哈哈
 楼主| 发表于 2005-12-5 18:44:45 | 显示全部楼层
  =rand(200,99)
  然后回车看看会发生什么? 变成了
"The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog.  The quick brown fox jumps over the lazy dog. ......"
2楼的你的名称是不是有空格呀?
我的机器XP的不行呀?
你是直接在Window下建的吗?还是在Linux下建的拷过来的?
发表于 2005-12-5 19:29:50 | 显示全部楼层
原来是相乘的关系,大家还是输入下面这个,免得死机,:)
=rand(1,2)
发表于 2005-12-5 19:42:37 | 显示全部楼层
第一个应该是彩蛋,肯定是微软故意的。
第二个中aux.con.nul是一些特殊设备的名称,也是微软规定的不能用于目录名,就好像有些字符不能用于文件名一样,没什么奇怪的。二楼的图是全角的字符,其内部代码并不是aux。
发表于 2005-12-5 21:58:53 | 显示全部楼层
试了,完全不行!
发表于 2005-12-8 14:10:07 | 显示全部楼层
第一个:那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。  那只敏捷的棕毛狐狸跃过那只懒狗。
发表于 2005-12-11 13:26:59 | 显示全部楼层
我用的是中文版,与八楼一样。用中文输入法没事。
发表于 2006-1-17 14:06:34 | 显示全部楼层
我知道2楼是怎么建的--------是在中文输入发中建立的,注意是全角模式的输入状态并且键盘上的CAPS LOCK要开启
GMT+8, 2026-11-22 11:20 , Processed in 0.451112 second(s), 33 queries , Gzip On, File On.
