查看: 1183|回复: 3
[分享]:VLDCL(用VLISP实现一些对话框的优化)网络收集分享
发表于 2005-12-15 22:56:09 | 显示全部楼层 |阅读模式
VLDCL is a Visual LISP programming tool for coding DCL based application from within Visual LISP IDE environment. VLDCL will classify all typed DCL Objects (DCL tiles) into 8 groups and define some useful properties to them. All properties will be defined in a global variable. VLDCL will scan the variable and make proper initialization (set_tile/mode_tile) and action (action_tile) definition functions so that the program structure will be established and maintained. By doing so, there will be less (or even none) set_tile/mode_tile/action_tile coding works while programming. All these functions will be defined and executed by VLDCL in memory. Modify, update and maintain the programs can be done simply by modifying properties data in global variable.
大家来看看,它是怎么实现的
 楼主| 发表于 2005-12-15 22:56:50 | 显示全部楼层
[iframe h=800 w=100%]http://www.ikozmos.com/htmls/vldcl-functions.htm[/iframe]
发表于 2005-12-16 09:22:30 | 显示全部楼层
斑主直接告诉大家网址得了。
里面有好多好东东。
发表于 2005-12-16 12:03:48 | 显示全部楼层
可惜是英文的,看不懂。那位高手翻译一下就好了。
GMT+8, 2026-11-22 08:20 , Processed in 0.370347 second(s), 16 queries , Gzip On, File On.
