查看: 1187|回复: 6
[求助] [求助]:[1225]请教矩形指令问题?
发表于 2005-12-25 08:06:11 | 显示全部楼层 |阅读模式
在指令行输入中绘制矩形指定另一对角点时可以输入
相对座标 如(@100,200)
想问的是在 LISP 中该怎样叙述呢
烦请各位高手解答~
谢谢~
已领礼包: 593个
发表于 2005-12-25 08:35:45 | 显示全部楼层
(vl-cmdf ".rectang" (getpoint "\nPoint: ") "@120,340")
 楼主| 发表于 2005-12-25 11:43:47 | 显示全部楼层
那如果将对此"@100,200"的值转换为
变数距离如 "@hh,dd"
该怎样叙述呢
已领礼包: 9347个
发表于 2005-12-25 12:51:52 | 显示全部楼层
(strcat "@" (rtos hh) "," (rtos dd))
 楼主| 发表于 2005-12-25 14:29:06 | 显示全部楼层
如果要在判断程序中数值得正值及负值该怎样处理呢
以下是小弟写的程序
但有问题
烦请各位高手修正一下
谢谢了
(defun c:ts ()
(setq pa (getpoint "Enter First Point:"))
(setq ww (getdist pa "\nWidth:"))
(setq hh (getdist pa "\nHeight:"))
(setq pc1 (list (+ (car pa) ww)(+ (cadr pa) hh)))
(setq pc2 (list (- (car pa) ww)(+ (cadr pa) hh)))
(setq pc3 (list (- (car pa) ww)(- (cadr pa) hh)))
(setq pc4 (list (+ (car pa) ww)(- (cadr pa) hh)))
(cond
(and(< ww 0)(< hh 0))
(command "RECTANG" pa pc1)
(and(> ww 0)(< hh 0))
(command "RECTANG" pa pc2)
(and(> ww 0)(> hh 0))
(command "RECTANG" pa pc3)
(and(< ww 0)(> hh 0))
(command "RECTANG" pa pc4)
发表于 2006-1-2 22:32:46 | 显示全部楼层
  1. [FONT=courier new](defun c:ts ()
  2.   (setq        pa  (getpoint "\nEnter First Point : ")
  3.         ww  (getdist pa "\nWidth : ")
  4.         hh  (getdist pa "\nHeight : ")
  5.         pc1 (list (+ (car pa) ww) (+ (cadr pa) hh))
  6.   )
  7.   (command "RECTANG" pa pc1)
  8.   (princ)
  9. )[/FONT]
发表于 2006-1-2 22:56:05 | 显示全部楼层
如果数值都知道了,干嘛还rectang,直接求四点entmake一条pline不是更直接?
GMT+8, 2026-11-6 21:49 , Processed in 0.449967 second(s), 44 queries , Gzip On.
