查看: 839|回复: 2
[求助]:求用VBA画正方形的程序
发表于 2006-1-15 12:54:15 | 显示全部楼层 |阅读模式
谁告诉我用VBA画正方形的程序???
谢谢
发表于 2006-1-15 13:08:28 | 显示全部楼层
下面是一个画矩形的程序,改改就可以画正方形
Sub DrawBox()
Dim objUtil As AcadUtility
Dim varPnt1 As Variant
Dim varPntLP As Variant
Dim dblPoints() As Double
Dim blnContinue As Boolean
Dim intcnt As Integer
Dim intPoints As Integer
Dim objPLine As AcadLWPolyline
Dim objNewPLine As AcadLWPolyline
On Error GoTo Err_Control
Set objUtil = ThisDrawing.Utility
varPnt1 = objUtil.GetPoint(, "Select First Point")
For intcnt = 0 To 1
ReDim Preserve dblPoints(intcnt)
    dblPoints(intcnt) = varPnt1(intcnt)
Next intcnt
intPoints = 2
varPntLP = varPnt1
Do Until blnContinue = True
    varPntLP = objUtil.GetPoint(varPntLP, "Select Next Point or <Enter> to Finish:")
    For intcnt = 0 To 1
    ReDim Preserve dblPoints(intPoints)
         dblPoints(intPoints) = varPntLP(intcnt)
         intPoints = intPoints + 1
    Next intcnt
Loop
Add_PLine:
Set objPLine = ThisDrawing.ModelSpace.AddLightWeightPolyline(dblPoints)
Set objNewPLine = objPLine.Offset(0.5)
Exit_Here:
Exit Sub
Err_Control:
Select Case Err.Number
Case -2145320928
    Err.Clear
    GoTo Add_PLine
Case Else
    MsgBox Err.Number & vbCr & Err.Description
End Select
End Sub
 楼主| 发表于 2006-1-15 13:11:26 | 显示全部楼层
能不能帮我改成正方形的?  谢谢!!我要考试!!
GMT+8, 2026-11-3 15:17 , Processed in 0.413777 second(s), 36 queries , Gzip On.
