查看: 2049|回复: 12
[求助] [求助]:求一程序,可以把块中块全部一个命令炸开?
发表于 2006-2-18 15:44:49 | 显示全部楼层 |阅读模式
有时在改图时,遇到块中块中块中块的情况,一个大块中套了n个小块,求一命令,可以一下子将所有的块全部炸开?
比如:一个大块中套了5层,每层又有5个块,想把它全部炸开,用explode,搞死人了?
谢谢!
已领礼包: 9333个
发表于 2006-2-18 22:11:58 | 显示全部楼层
  1. ;|
  2. From: "Doug Broad"
  3. Newsgroups: autodesk.autocad.customization
  4. Subject: Re: LISP explode doesn't work
  5. Great points Joe.  I overlooked xrefs.  Oops.
  6. Looked at your program and made a few changes.  What
  7. do you think?
  8. |;
  9. ;;A program by Joe Burke with changes by D.C. Broad
  10. ;;Explode all inserts - skip xrefs.
  11. (defun c:xpAll (/ doc mspace blockflag)
  12.   (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
  13.   (setq mspace (vla-get-ModelSpace doc))
  14.   (setq blockflag t)
  15.   ;;loop until no blocks are found.
  16.   (while blockflag
  17.     (setq blockflag nil)
  18.     (vlax-for x mspace
  19.       (cond
  20.         ((and
  21.            (= "AcDbBlockReference" (vlax-get x 'ObjectName))
  22.            (not (vlax-property-available-p x 'Path))
  23.          )
  24.          ;;if a block is found assume it might have a nested
  25.          ;;block and loop again.
  26.          (setq blockflag t)
  27.          (vla-explode x)
  28.          (vla-delete x)
  29.         )
  30.       )
  31.     )
  32.   )
  33.   (princ)
  34. )
发表于 2006-2-19 09:38:35 | 显示全部楼层
命令:  XPALL ; 错误: Automation 错误。 输入无效
能不能炸多重块?
发表于 2006-2-19 10:37:39 | 显示全部楼层
;随手写的,未经测试
[php]
(defun c:xx ()
  (setvar "qaflags" 1)
(if (setq ss (ssget '((0 . "INSERT"))))
    (progn
      (while ss
        (command ".explode" ss "")
        (setq ss (ssget "p" '((0 . "INSERT"))))
(princ)
[/php]
发表于 2006-2-19 13:48:15 | 显示全部楼层
上楼的有问题
(LOAD "F:/CAD命令加载/123.lsp") ; 错误: 输入的列表有缺陷
请核查下。
已领礼包: 838个
发表于 2006-2-19 15:48:16 | 显示全部楼层
4楼的不能用,2楼的倒是可以,但命令行有不相关的提示
已领礼包: 9333个
发表于 2006-2-19 15:58:57 | 显示全部楼层
最初由 userzhluserzhl 发布
[B]命令:  XPALL ; 错误: Automation 错误。 输入无效
能不能炸多重块? [/B]
Ref Help file
Loads Visual LISP extensions to AutoLISP
(vl-load-com)
This function loads the extended AutoLISP functions provided with Visual LISP.
The Visual LISP extensions implement ActiveX and
AutoCAD reactor support through AutoLISP,
and also provide ActiveX utility and data conversion functions,
dictionary handling functions, and curve measurement functions.
If the extensions are already loaded, vl-load-com does nothing.
发表于 2006-2-19 16:16:17 | 显示全部楼层
少了括号,重贴如下
[php]
(defun c:xx ()
    (progn
      (while ss
  (princ)
[/php]
发表于 2006-2-19 17:23:37 | 显示全部楼层
最初由 雨箭风刀 发布
[B]少了括号,重贴如下……[/B]
  1. [FONT=courier new]
  2. (defun c:test ()
  3.   (setvar "qaflags" 1)
  4.   (setq ss (ssget '((0 . "INSERT"))))
  5.   (while (setq ss (ssget "P" '((0 . "INSERT"))))
  6.     (command ".explode" ss "")
  7.   )
  8.   (princ)
  9. )[/FONT]
 楼主| 发表于 2006-2-21 01:08:31 | 显示全部楼层
各位大哥,小弟一事不解:
请问qaflags这个变量是干什么的?有什么作用呀?
为什么我在CAD的帮助中找不到这个变量的相关说明呀?
设置为0,和设置为1,各有什么作用呀?
谢谢!
发表于 2006-2-21 08:47:58 | 显示全部楼层
请教一下这个setvar "qaflags" 系统变数是做什么用的,是内定的吗?
烦请解答一下
谢谢~
已领礼包: 9333个
发表于 2006-2-21 08:48:19 | 显示全部楼层
http://www.jtbworld.com/autocadtips.htm
What is QAFLAGS?
QAFLAGS been used a long time (<r12) by developers and autodesk themself too.
QAFLAGS acceps a value between 0 and 32767
bit 0 (1) : ^C in menu macro cancels grips (acts like keyboard <Esc>).
bit 1 (2) : no pause during text screen listings.
bit 2 (4) : no "alert" dialogs (text display instead).
bit 7 (128) : accepts "screen picks" (point lists) via (command) function.
Normally QAFLAGS should be set to 0. Because it might be set to
other values it is a good idea to put (setvar "QAFLAGS" 0) in
acaddoc.lsp or any other of your lisp files that you use for startup.
发表于 2007-6-12 23:37:28 | 显示全部楼层
好行不行也,是我不会用还是真的不行,小弟不才,请大侠说的明白点
GMT+8, 2026-11-2 03:12 , Processed in 0.471545 second(s), 56 queries , Gzip On.
