查看: 1994|回复: 4
[求助] [求助]:initget命令如何使用?
发表于 2006-2-28 15:25:48 | 显示全部楼层 |阅读模式
(initget 1 "Yes No")
已领礼包: 9339个
发表于 2006-2-28 20:02:16 | 显示全部楼层
Arguments
bits
A bit-coded integer that allows or disallows certain types of user input.
The bits can be added together in any combination to form a value between 0 and 255.
If no bits argument is supplied, zero (no conditions) is assumed.
The bit values are as follows:
1 (bit 0)  Prevents the user from responding to the request by entering only ENTER.
2 (bit 1)  Prevents the user from responding to the request by entering zero.
4 (bit 2)  Prevents the user from responding to the request by entering a negative value.
8 (bit 3)  Allows the user to enter a point outside the current drawing limits.
This condition applies to the next user-input function even if
the AutoCAD system variable LIMCHECK is currently set.
16 (bit 4)  (Not currently used.)
32 (bit 5)  Uses dashed lines when drawing a rubber-band line or box.
For those functions with which the user can specify a point by
selecting a location in the drawing area, this bit value causes
the rubber-band line or box to be dashed instead of solid.
(Some display drivers use a distinctive color instead of dashed lines.)
If the system variable POPUPS is 0, AutoCAD ignores this bit.
64 (bit 6)  Prohibits input of a Z coordinate to the getdist function;
lets an application ensure that this function returns a 2D distance.
128 (bit 7)  Allows arbitrary input as if it is a keyword,
first honoring any other control bits and listed keywords.
This bit takes precedence over bit 0;
if bits 7 and 0 are set and the user presses ENTER, a null string is returned.
Note  Future versions of AutoLISP may use additional initget control bits,
so avoid setting bits that are not listed here.
string
A string representing a series of keywords.
See Keyword Specifications for information on defining keywords.
 楼主| 发表于 2006-3-1 10:41:00 | 显示全部楼层
能不能给个中文的,英文看不懂。谢谢!
已领礼包: 9339个
发表于 2006-3-1 10:56:59 | 显示全部楼层
 楼主| 发表于 2006-3-1 15:41:03 | 显示全部楼层
一个很好的网站,谢谢4楼。
GMT+8, 2026-11-4 02:30 , Processed in 0.482930 second(s), 40 queries , Gzip On.
