查看: 914|回复: 3
[ARX函数]:如何得到圆和线的交点?
发表于 2003-5-7 16:35:31 | 显示全部楼层 |阅读模式
如何得到圆和线的交点?
发表于 2003-5-8 10:34:19 | 显示全部楼层
virtual Acad::ErrorStatus
intersectWith(
const AcDbEntity* pEnt,
AcDb::Intersect intType,
AcGePoint3dArray& points,
int thisGsMarker = 0,
int otherGsMarker = 0) const;
pEnt Input entity with which "this" entity is to intersect
intType Input type of intersection requested
points Output with the points of intersection appended
thisGsMarker Input GS marker of subentity of "this" entity that's involved in the intersection operation. Use the 0 default if not applicable.
otherGsMarker Input GS marker of subentity of the entity pointed to by pEnt that's involved in the intersection operation. Use the 0 default if not applicable.
 楼主| 发表于 2003-5-8 16:10:29 | 显示全部楼层
对不起我的水平很差,不太明白
如果我有了一个圆circle,有一直线line我该如何做呢?
发表于 2003-8-17 23:23:47 | 显示全部楼层
为了提高速度,可先构造园和直线的几何类,再用intersect()函数即可求出交点,另外,可利用牛顿拟迭代法可顺速求出交点
GMT+8, 2026-11-4 17:25 , Processed in 0.584535 second(s), 38 queries , Gzip On.
