查看: 1026|回复: 2
[求助] [求助]:有没有什么函数可以得出当前CAD开了几个文档?
发表于 2006-3-3 08:40:14 | 显示全部楼层 |阅读模式
已领礼包: 9347个
发表于 2006-3-3 08:55:20 | 显示全部楼层
(defun GetDocsCollection (/ ThisApp colDocs)
  (vl-load-com)
  (setq thisApp (vlax-get-acad-object))
  (setq colDocs (vla-get-documents thisApp))
  (vl-bb-set 'colDocs colDocs)
(defun CheckOrCreateDocs (/ colDocs)
  (vl-load-com)
  (if (= colDocs nil)
    (if        (= (setq colDocs (vl-bb-ref 'colDocs)) nil)
      (GetDocsCollection)
(defun CountOpenDwgs (/ colDocs)
  (CheckOrCreateDocs)
  (vla-get-count colDocs)
(defun ListOpenDwgs (/ colDocs totOpenDwgs lKounter dwgList)
  (setq totOpenDwgs (CountOpenDwgs))
  (setq lKounter 0)
  (setq dwgList (list))
  (while (< lKounter totOpenDwgs)
    (setq
      dwgList (append
                dwgList
                (list (vla-get-FullName (vla-item colDocs lKounter)))
    (setq lKounter (1+ lKounter))
  (setq dwgList dwgList)
info: http://www.cadchat.com/forums/lofiversion/index.php/t877.html
 楼主| 发表于 2006-3-3 09:18:33 | 显示全部楼层
谢谢 Underway
GMT+8, 2026-11-7 00:49 , Processed in 0.483083 second(s), 36 queries , Gzip On.
