查看: 1393|回复: 2
[求助]:请帮我看看这程序 急急!
发表于 2002-5-10 00:55:57 | 显示全部楼层 |阅读模式
Acad::ErrorStatus ZhouPolyDB1::drawDim(const ZhouPolyDB1* elevDim,
                AcGiWorldDraw * worldDraw,
                AcGiViewportDraw* vportDraw)
        AcGePoint2d p1[5];
        AcGePoint2d p2;
        double DD1;
//NUM 1 外围
        AcDbPolyline *PolyLine=new AcDbPolyline(5);
        if(m_StartPoint[X]>m_EndPoint[X])
                DD1=m_EndPoint[X];
                m_EndPoint[X]=m_StartPoint[X];
                m_StartPoint[X]=DD1;
        if(m_StartPoint[Y]>m_EndPoint[Y])
                DD1=m_EndPoint[Y];
                m_EndPoint[Y]=m_StartPoint[Y];
                m_StartPoint[Y]=DD1;
        p2.set(m_StartPoint.x,m_StartPoint.y);
        p1[0]=p2;
        p2.set(m_EndPoint.x,m_StartPoint.y);
        p1[1]=p2;
        p1[2].set(m_EndPoint.x,m_EndPoint.y);
        p2.set(m_StartPoint.x,m_EndPoint.y);
        p1[3]=p2;
        p1[4]=p1[0];
        PolyLine->addVertexAt(0,p1[0]);
        PolyLine->addVertexAt(1,p1[1]);
        PolyLine->addVertexAt(2,p1[2]);
        PolyLine->addVertexAt(3,p1[3]);
        PolyLine->addVertexAt(4,p1[4]);
        Adesk::Boolean BBB;
        BBB=worldDraw->geometry().pline(*PolyLine);
        if(BBB==Adesk::kFalse)
                MessageBox(NULL,"YES","YES",1);
        else
                MessageBox(NULL,"NO","NO",1);
        return Acad::eOk;
//内围
        AcDbVoidPtrArray PArray;
        PolyLine->getOffsetCurves(20,PArray);
        AcDbPolyline *PolyLine1;
        PolyLine1=(AcDbPolyline *)PArray[0];
        worldDraw->geometry().pline(*PolyLine1);
        delete PolyLine;
程序运行出错
发现BBB==Adesk::kFalse,说明是正确的,但后面就出错了,我想PolyLine应该用delete,不知对不对?
 楼主| 发表于 2002-5-10 01:01:00 | 显示全部楼层
我的目的是想扩展一个AcDbEntity类对象,该对象有两个AcDbPolyline实体,且这两个是用Offset偏离得到的,请问有其他办法吗?
发表于 2002-5-10 02:19:08 | 显示全部楼层
仔细看看pline函数的参数,pline函数的参数是一个二维点数组,不是AcDbPolyline实体。
GMT+8, 2026-11-2 00:00 , Processed in 0.403328 second(s), 36 queries , Gzip On.
