查看: 1280|回复: 0
[求助]:[求助]:[求助]:斑主请看看这个?
发表于 2007-11-12 09:02:51 | 显示全部楼层 |阅读模式
是这样的。'=====================================================================================================Call Example_InsertBlock(a)'a 是不定字符变量,根据要求建立不同的块名。for i=1 to n'n值会在程序的其它地方给定此处未知   Call Example_Addline(x1,y1,x2,y2)'有关参数值的程序已被略掉   Call Example_AddCircle(x,y,r)
Next i'==============我是想把以上部分画的图元加入到未知变量“a”的块中========================================   Sub Example_AddLine(x1 as double,y1 as double,x2 as double,y2 as double)
    Dim lineObj As AcadLine    Dim startPoint(0 To 2) As Double    Dim endPoint(0 To 2) As Double
    startPoint(0) = x1: startPoint(1) = y1: startPoint(2) = 0#    endPoint(0) = x2: endPoint(1) = y2: endPoint(2) = 0#
        Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)    ZoomAll
End SubSub Example_AddCircle(x1 as double,y1 as double,r as double)
    Dim circleObj As AcadCircle    Dim centerPoint(0 To 2) As Double    Dim radius As Double
    centerPoint(0) = x1: centerPoint(1) = y1: centerPoint(2) = 0#    radius = r
     Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
End Sub
GMT+8, 2026-11-22 08:34 , Processed in 0.258569 second(s), 10 queries , Gzip On, File On.
