查看: 2909|回复: 2
[VBA函数]:返回 空间平面方程
发表于 2007-12-2 14:22:27 | 显示全部楼层 |阅读模式
  1. '空间平面方程
  2. Function KJPMFC(P1 As Variant, P2 As Variant, P3 As Variant, ByRef A As Double, ByRef B As Double, ByRef C As Double, ByRef D As Double) As Integer
  3.     '判断三点是否在一条直线上
  4.     If ThreeP_IsOnline(P1, P2, P3) = True Then
  5.         ThisDrawing.Utility.Prompt "出现三点共线情况" & vbCrLf
  6.         Exit Function
  7.     End If
  8.     Dim M(0 To 5) As Double
  9.     '计算平面方程系数
  10.     M(0) = P2(0) - P1(0)
  11.     M(1) = P2(1) - P1(1)
  12.     M(2) = P2(2) - P1(2)
  13.     M(3) = P3(0) - P1(0)
  14.     M(4) = P3(1) - P1(1)
  15.     M(5) = P3(2) - P1(2)
  16.     '计算平面方程系数( Ax+By+Cz+D=0)
  17.     A = M(1) * M(5) - M(2) * M(4)
  18.     B = -(M(0) * M(5) - M(2) * M(3))
  19.     C = M(0) * M(4) - M(1) * M(3)
  20.     D = -A * P1(0) - B * P1(1) - C * P1(2)
  21. End Function
发表于 2010-2-18 03:59:56 | 显示全部楼层
学习了!!
发表于 2014-6-12 21:17:41 | 显示全部楼层
终于找到源码了的,谢谢
GMT+8, 2026-11-22 07:46 , Processed in 0.677906 second(s), 15 queries , Gzip On, File On.
