查看: 935|回复: 3
[求助] [求助]:用什么办法在画多段线时控制橡皮筋成直角
发表于 2006-3-20 16:51:06 | 显示全部楼层 |阅读模式
用什么办法在画多段线时控制橡皮筋一直向上一条边只成直角运动
望赐教
登录/注册后可看大图
发表于 2006-3-20 17:49:51 | 显示全部楼层
程序不太完善,最好加上出错处理,防止"snapang"角度变不回来
[php]
(defun c:test ()
  (command "pline" pause)
  (setq p0 (getvar "lastpoint"))
  (command pause)
  (setq p1 (getvar "lastpoint"))
  (if (= (setq ort (getvar "ORTHOMODE")) 0)
    (setvar "ORTHOMODE" 1)
  (setq ang (angle p0 p1))
  (setvar "snapang" ang)
  (command pause)
  (while (not (equal (setq p0 (getvar "lastpoint")) p1 0.00001))
    (command pause)
    (setq p1 p0)
  (setvar "snapang" 0)
  (setvar "ORTHOMODE" ort)
  (princ)
)[/php]
 楼主| 发表于 2006-3-20 18:16:13 | 显示全部楼层
哈哈!!不问不知道原来就是改"ORTHOMODE"和"SNAPANG"变量
谢ljpnb 楼主了!!!
发表于 2006-3-20 18:21:33 | 显示全部楼层
高手
GMT+8, 2026-11-7 01:31 , Processed in 0.410105 second(s), 37 queries , Gzip On.
