查看: 1402|回复: 1
[VBA程序]:acad map vba入门的例子
发表于 2006-3-21 20:57:49 | 显示全部楼层 |阅读模式
Sub tableproc()
Dim amap As AcadMap
Dim ODfdfs As ODFieldDefs
Dim ODfdf As ODFieldDef
Dim ODtb As ODTable
Dim ODrc As ODRecord
Set amap = ThisDrawing.Application. GetInterfaceObject("AutoCADMap.Application")
'Create OD Table Definition
Set ODfdfs = amap.Projects(ThisDrawing).MapUtil.NewODFieldDefs
' Add Column Headings and Defaults
Set ODfdf = ODfdfs.Add("Entity", "Entity name", "", 0)
Set ODfdf = ODfdfs.Add("Color", "Object color", acRed, 1)
Set ODfdf = ODfdfs.Add("Layer", "Object layer", "0", 2)
'Ensure Table Does Not Exist
If amap.Projects(ThisDrawing).ODTables.Item("SampleOD2") Is Nothing Then
'Register OD Table in the drawing
Set ODtb = amap.Projects(ThisDrawing) .ODTables.Add("SampleOD2", "Sample Xdata", ODfdfs, True)
'Create OD Record with Defaults
Set ODrc = ODtb.CreateRecord
'Loop Through Entities in Model Space
For Each acadObj In ThisDrawing.ModelSpace
'Fill Records with Entity Data
ODrc.Item(0).Value = acadObj.EntityName
ODrc.Item(1).Value = acadObj.Color
ODrc.Item(2).Value = acadObj.Layer
'Attach Record to Entity
ODrc.AttachTo (acadObj.ObjectID)
Next
Else
'Table Already Exists
MsgBox "Unable to create " & "SampleOD", , "Object Data Table Error"
End If
End Sub
发表于 2006-4-17 01:17:49 | 显示全部楼层
先下来看看再说,先顶为上!
GMT+8, 2026-11-22 09:09 , Processed in 0.359306 second(s), 12 queries , Gzip On, File On.
