查看: 1048|回复: 1
[ARX程序]:救命:编译出了102个错!!
发表于 2002-5-10 08:37:47 | 显示全部楼层 |阅读模式
如下:
Compiling...
QuxianDlg.cpp
D:\rail\rail\QuxianDlg.cpp(130) : error C2065: 'AcDbArc' : undeclared identifier
D:\rail\rail\QuxianDlg.cpp(130) : error C2065: 'pArc' : undeclared identifier
D:\rail\rail\QuxianDlg.cpp(130) : warning C4552: '*' : operator has no effect; expected operator with side-effect
D:\rail\rail\QuxianDlg.cpp(132) : error C2061: syntax error : identifier 'AcDbArc'
D:\rail\rail\QuxianDlg.cpp(133) : error C2039: 'acdbHostApplicationServices' : is not a member of 'AcDbDatabase'
        d:\objectarx 2000\inc\dbmain.h(240) : see declaration of 'AcDbDatabase'
D:\rail\rail\QuxianDlg.cpp(133) : error C2227: left of '->workingDatabase' must point to class/struct/union
D:\rail\rail\QuxianDlg.cpp(134) : error C2065: 'pCurb' : undeclared identifier
D:\rail\rail\QuxianDlg.cpp(134) : error C2227: left of '->getBlockTable' must point to class/struct/union
D:\rail\rail\QuxianDlg.cpp(135) : error C2027: use of undefined type 'AcDbBlockTable'
        d:\objectarx 2000\inc\dbmain.h(61) : see declaration of 'AcDbBlockTable'
D:\rail\rail\QuxianDlg.cpp(135) : error C2227: left of '->getAt' must point to class/struct/union
D:\rail\rail\QuxianDlg.cpp(136) : error C2027: use of undefined type 'AcDbBlockTableRecord'
        d:\objectarx 2000\inc\dbmain.h(62) : see declaration of 'AcDbBlockTableRecord'
D:\rail\rail\QuxianDlg.cpp(136) : error C2227: left of '->appendAcDbEntity' must point to class/struct/union
D:\rail\rail\QuxianDlg.cpp(137) : error C2027: use of undefined type 'AcDbBlockTableRecord'
D:\rail\rail\QuxianDlg.cpp(137) : error C2227: left of '->close' must point to class/struct/union
D:\rail\rail\QuxianDlg.cpp(138) : error C2027: use of undefined type 'AcDbBlockTable'
D:\rail\rail\QuxianDlg.cpp(138) : error C2227: left of '->close' must point to class/struct/union
D:\rail\rail\QuxianDlg.cpp(139) : error C2227: left of '->close' must point to class/struct/union
D:\rail\rail\QuxianDlg.cpp(179) : error C2143: syntax error : missing ';' before '}'
D:\rail\rail\QuxianDlg.cpp(179) : fatal error C1003: error count exceeds 100; stopping compilation
Error executing cl.exe.
Chenrail.arx - 102 error(s), 1 warning(s)
怎么办?
发表于 2002-5-10 09:03:43 | 显示全部楼层
加上这几个头文件试一下
#include "dbents.h"           // 'old' 2D polyline
#include "dbcurve.h"          // Curve base class
#include "dbmain.h"           // Entity base class
GMT+8, 2026-11-1 23:28 , Processed in 0.418022 second(s), 34 queries , Gzip On.
