查看: 1080|回复: 1
[求助]:线型问题
发表于 2003-5-10 23:10:38 | 显示全部楼层 |阅读模式
如果当前图纸没有加载这种线型,如何加载AutoCAD预定义的线型?
已领礼包: 145个
发表于 2003-5-11 00:21:43 | 显示全部楼层
Re: [求助]:线型问题
最初由 ljhqfljhqf 发布
[B]如果当前图纸没有加载这种线型,如何加载AutoCAD预定义的线型? [/B]
你可以用 ads_command 调用 linetype 命令加载acad.lin 文件
如果不希望使用命令调用,你可以用纯ARX方法,这些在帮助文件里面都提供了,用 loadline.....就会出来的。需要记住的是,在ACAD下面,没有ARX做不了的,而所有方法都在帮助文件里面可以查到用法
  1. <normalfont>
  2. AcDbDatabase::loadLineTypeFile Function Acad::ErrorStatus
  3. loadLineTypeFile(
  4. const char * ltn,
  5. const char * filename);
  6. ltn Input linetype name string (wild cards may be used)
  7. filename Input path/filename or
  8. URL of linetype file to load from (path is optional)
  9. This function loads the linetype specified by ltname from
  10. the file specified by fname and
  11. stores it in the database on which this method is called.
  12. The ltname parameter may contain wild card characters (see the ads_wcmatch() documentation
  13. for more information on wild card usage). If wild cards are used, multiple linetypes may be loaded.
  14. If fname is not a URL and does not contain a path, then the AutoCAD
  15. library search path is searched for the file.
  16. Returns Acad::eOk if successful.
  17. Returns Acad::eNullObjectPointer if ltname or fname is NULL.
  18. Returns Acad::eFileSystemErr if the specified file cannot be opened.
  19. Returns Acad::eUndefinedLineType if the linetype name specified by
  20. ltname is not found in the file.
  21. Returns Acad::eBadLineTypeName if the file contains a malformed record, or a syntax error is encountered.
  22. Returns an appropriate Internet-specific Acad::ErrorStatus value if a URL
  23. is specified and the transfer is not successful
  24. </normalfont>
GMT+8, 2026-11-3 12:11 , Processed in 0.461656 second(s), 34 queries , Gzip On.
