查看: 1083|回复: 8
[文章]:角度怎么查询??
发表于 2006-4-6 09:15:30 | 显示全部楼层 |阅读模式
最近在做CAD的练习,不少要查询角度的,请问各位大侠,任意两条直线的角度有什么好一点的办法查询?在CAXA中很好查。到了AUTOCAD好象难办一点。
发表于 2006-4-6 09:34:45 | 显示全部楼层
俺有个苯办法,直接用标注,确定标注位置的时候点右键取消就行了(会不会麻烦了点)
发表于 2006-4-6 10:32:06 | 显示全部楼层
用命令DIMANGULAR或DIST
发表于 2006-4-6 10:50:49 | 显示全部楼层
我一直用的都是这个办法,在CAD里面我不知道别的太好的办法
发表于 2006-4-6 19:31:25 | 显示全部楼层
在标注样式里设置你需要的精度(COMMAND:D)用标注角度的命令(COMMAND:DAN),
 楼主| 发表于 2006-4-6 19:32:41 | 显示全部楼层
谢谢各位的指点!!!
发表于 2006-4-6 20:36:42 | 显示全部楼层
[B][php]
(Defun *error* (msg)
        (princ "错误:")
        (princ msg)
        (terpri)
(Defun C:JD        (/                                 cmde                         ent_1                 ent_2                 ent_1_name
                                                 ent_2_name                                         ang_1                 ang_2                 ang
                                                 ang_yj                 ang_min         ang_max
        (Defun TQ_ENT_NAME (ent)
                (eval '(cdr (assoc '0 (entget (car ent)))))
        (Defun TQ_ANG        (ent)
                (setq        ang        (angle (cdr (assoc 10 (entget (car ent))))
        (cdr (assoc 11 (entget (car ent))))
        (setq cmde (getvar "cmdecho"))
        (setvar "cmdecho" 0)
        (setq ent_1 (entsel "\n测量两线夹角,选第一条直线:"))
        (if        ent_1
                (progn
                        (princ "OK!")
                        (setq ent_1_name (TQ_ENT_NAME ent_1))
                        (if        (= ent_1_name "LINE")
                                (progn
                                        (setq ang_1 (TQ_ANG ent_1))
                                        (redraw (car ent_1) 3)
                        (if        ang_1
                                (progn
                                        (setq ent_2 (entsel "\n选第二条直线:"))
                                        (if        ent_2
                                                (progn
                                                        (princ "OK!")
                                                        (princ)
                                                        (setq ent_2_name (TQ_ENT_NAME ent_2))
                                                        (if        (= ent_2_name "LINE")
        (progn
        (setq ang_2 (TQ_ANG ent_2))
        (redraw (car ent_2) 3)
        (princ)
                                                        (if        (and ang_1 ang_2)
        (progn
        (setq ang (abs (- ang_1 ang_2)))
        (if        (> ang pi)
        (setq ang (- ang pi))
        (setq        ang                        (* ang (/ 180 pi))
        ang_yj        (- 180 ang)
        ang_min        (min ang ang_yj)
        ang_max        (max ang ang_yj)
        (setq        ang_min        (rtos ang_min 2 4)
        ang_max        (rtos ang_max 2 4)
        (alert
        (strcat        "\n 夹   角α = "                ang_min
        "° \n\n 180°- α = "
        ang_max                                                        "°"
        (princ "\n所求夹角=")
        (princ ang_min)
        (princ "\°  180°- 夹角=")
        (princ ang_max)
        (princ "°")
        (redraw (car ent_1) 4)
        (redraw (car ent_2) 4)
                                                (progn
                                                        (princ "\n未选中第二条直线!")
                (princ "\n未选中第一条直线!")
        (setvar "cmdecho" cmde)
        (princ)
[/php] [/B]
发表于 2006-4-7 00:05:53 | 显示全部楼层
命令行:输入dan,选中line,next line又简单又快捷。
发表于 2006-4-12 09:01:41 | 显示全部楼层
呵呵,我也学到了,谢谢大侠
GMT+8, 2026-8-29 11:22 , Processed in 0.580434 second(s), 48 queries , Gzip On.
