查看: 1103|回复: 0
[求助]:修改CAD2006机械版部件数据
发表于 2006-4-21 09:52:24 | 显示全部楼层 |阅读模式
我使用autocad2006 type lib、autodesk mcadauto2.0 type lib 和 autodesk symbbauto2.0 type lib, 可以修改bom序号和数量,但是修改不了部件的数据,请高手介绍一种方法,用arx也行,拜谢!!!
vb修改程序如下:
  Dim acadApp As acadApplication
    Dim mcadApp As McadApplication
    Dim idoc As IMcadDocument
    Dim ibom As IMcadBOMItem
    Set acadApp = GetObject(, "AUTOCAD.Application.16")
    Set mcadApp = acadApp.GetInterfaceObject("Mcad.Application")
    Set idoc = mcadApp.ActiveDocument
    Dim mpart As IMcadPartList
Set mpart = idoc.HostDocument.ModelSpace.Item(13)  '此处取得IMcadPartList对象
'修改bom序号和数量
mpart.ItemList(3).Quantity = 88
mpart.ItemList(3).ItemNumber = "33"
mpart.Update
'修改部件数据
mpart.ItemList(3).Data(1, 1) = "dsfsf"  '此处取一个部件属性进行修改,无效???
mpart.Update
GMT+8, 2026-11-22 09:24 , Processed in 0.303725 second(s), 11 queries , Gzip On, File On.
