查看: 1690|回复: 7
[求助]:关于创建块引用实体的,高手帮忙看一下为什么显示不出来
发表于 2006-4-23 14:14:29 | 显示全部楼层 |阅读模式
请高手帮忙分析一下,为什么运行后图块显示不出来,谢谢了!
        AcDbBlockTableRecord *pLtBlockTableRec
                =new AcDbBlockTableRecord();
        pLtBlockTableRec->setName("ASDK_BLOCK_LT2");
        //获取块表
        AcDbBlockTable *pBlockTable=NULL;
        acdbCurDwg()->getSymbolTable(pBlockTable,AcDb::kForWrite);
        //将新建的块表记录加入到块表中
        AcDbObjectId blockId;
        pBlockTable->add(blockId,pLtBlockTableRec);
        pBlockTable->close();
acedGetPoint(NULL,"请选择圆形冷铁的圆心",center);
  AcDbCircle *pCircle=new AcDbCircle;
        CopyPoint(basePoint,center);
        pCircle->setCenter(basePoint);
        pCircle->setRadius(lt2_radius);
        //AcDbCircle *pCir;
        //pCir=new AcDbCircle(center,(0,0,1),lt2_radius);
        if (acdbEntLast(ent_lt2[0])!=RTNORM) {
                acdbFail("\nFail create last entity.");
                return;
        AcDbObjectId circleId;
        pLtBlockTableRec->appendAcDbEntity(circleId,pCircle);
    //画两条交叉线并将它们作为部件加入块表中
        AcGePoint3d pt1,pt2,pt3,pt4;
        acutPolar(center,PI/4,lt2_radius,asDblArray(pt1));//获得与圆心成45度角的圆周点
        acutPolar(center,5*PI/4,lt2_radius,asDblArray(pt2));
        acutPolar(center,3*PI/4,lt2_radius,asDblArray(pt3));
        acutPolar(center,7*PI/4,lt2_radius,asDblArray(pt4));
        AcDbLine *pLine;
        pLine=new AcDbLine(pt1,pt2);
        AcDbObjectId lineId1;
        //AddEntityToDbs(pLine);
        pLtBlockTableRec->appendAcDbEntity(lineId1,pLine);
        pLine->close();
        pLine=new AcDbLine(pt3,pt4);
        AcDbObjectId lineId2;
        pLtBlockTableRec->appendAcDbEntity(lineId2,pLine);
        pLine->close();
        pLtBlockTableRec->close();
AcDbBlockReference *pBlkRef=new AcDbBlockReference;
        pBlkRef->setBlockTableRecord(blockId);
        struct resbuf to,from;
        from.restype=RTSHORT;
        from.resval.rint=1;
        to.restype=RTSHORT;
        to.resval.rint=0;
        AcGeVector3d normal(0.0,0.0,1.0);
        acedTrans(&(normal.x),&from,&to,Adesk::kTrue,&(normal.x));
        pBlkRef->setPosition(basePoint);
        pBlkRef->setRotation(0.0);
        pBlkRef->setNormal(normal);
        acdbCurDwg()->getSymbolTable(pBlockTable,AcDb::kForRead);
        AcDbBlockTableRecord *pBlockTableRec;
        pBlockTable->getAt(ACDB_MODEL_SPACE,pBlockTableRec,AcDb::kForWrite);
        AcDbObjectId newEntId;
        pBlockTableRec->appendAcDbEntity(newEntId,pBlkRef);
        pBlockTableRec->close();
        INSERT("ASDK_BLOCK_LT2",center,1,"0");
发表于 2006-4-23 19:20:46 | 显示全部楼层
看看是不是把这句放到块内图形添加的代码后
发表于 2006-4-23 19:46:12 | 显示全部楼层
pBlkRef->close();      //这句话你忘了
 楼主| 发表于 2006-4-23 20:08:51 | 显示全部楼层
刚才我试了
出现了崩溃
有提示:Invalid  type in acutBulidList() arg#g
还有一个图C:\Documents and Settings\lihui\桌面[/IMG]
发表于 2006-4-23 22:50:53 | 显示全部楼层
INSERT("ASDK_BLOCK_LT2",center,1,"0"); 这句干什么用?
return;
这些又是干什么的?
 楼主| 发表于 2006-4-24 09:03:44 | 显示全部楼层
INSERT("ASDK_BLOCK_LT2",center,1,"0");这句话是插入刚才我定义的块,INSERT是我自定义的宏!这个宏没错,但是后面的参数有问题,我调试了就到这句出问题,但不知道该怎么改
return;
}这个是获得最后一个实体啊,没有错!
发表于 2006-4-25 09:17:12 | 显示全部楼层
好像没有问题,是不是对块的操作有误.
 楼主| 发表于 2006-4-25 09:35:07 | 显示全部楼层
我已经找到了INSERT("ASDK_BLOCK_LT2",center,1,"0");这句是多余的,因为我已经将块引用加入到模型空间中了!谢谢大家!
GMT+8, 2026-11-22 09:47 , Processed in 0.251882 second(s), 24 queries , Gzip On, File On.
