查看: 827|回复: 0
[求助] [求助]:ET工具中一个函数的用法
发表于 2006-4-24 11:41:17 | 显示全部楼层 |阅读模式
以下为ET工具中的一个函数。判断某键是否按下。
ET已经提供了两个相关的函数。分别是
(ACET-SYS-SHIFT-DOWN)
(ACET-SYS-CONTROL-DOWN)
现在的问题是如何判断其它的键,如ALT的状态
下面这个函数中的keycode值是什么?
请对此有研究的朋友帮个忙解答下。
(acet-sys-keystate keycode)
Check state of virtual key.
Arguments
keycode The code for the virtual key to test.
Return Values
The status of the specified virtual key:
If the high-order bit is 1, the key is down; otherwise, it is up.
If the low-order bit is 1, the key is toggled. A key, such as the CAPS LOCK key, is toggled if it is turned on. The key is off and untoggled if the low-order bit is 0. A toggle key's indicator light (if any) on the keyboard will be on when the key is toggled, and off when the key is untoggled.
Note:
See the documentation for the GetKeyState() Win32 function for additional details.
GMT+8, 2026-11-4 05:16 , Processed in 0.573232 second(s), 32 queries , Gzip On.
