查看: 1106|回复: 2
[求助]:怎么获得标注样式的ID
发表于 2006-5-7 11:32:14 | 显示全部楼层 |阅读模式
知道标注样式的名字,怎么获得他的ID
还有其他的如图层,块等等
发表于 2006-5-7 11:59:06 | 显示全部楼层
use the "getAt()" function
Acad::ErrorStatus
getAt(
    const char* entryName,
    AcDbObjectId& recordId,
    bool getErasedRecord = false) const;
entryName        Input name of record to search for
recordId        Returns with object ID of record with name entryName
getErasedRecord        Input bool indicating whether or not to find an erased record
This function searches the DimStyleTable for the record with name entryName and, if found, returns the AcDbObjectId of the record in recordId. If getErasedRecord==true, then matches against erased records are possible.
Possible return ErrorStatus codes are:  Acad::eOk, Acad::eKeyNotFound, or Acad::ePermanentlyErased.
void test()
        // TODO: Implement the command
        AcDbDimStyleTable *pDimStyleTable;
        Acad::ErrorStatus es;
        es=acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pDimStyleTable,AcDb::kForRead);
        if(es!=Acad::eOk)
                return;
        AcDbObjectId dId;
        pDimStyleTable->getAt("STANDARD",dId);
        pDimStyleTable->close();
        acutPrintf("\nThe Object's Id= %d",dId);
发表于 2006-5-15 22:50:09 | 显示全部楼层
这我正需要,谢谢!
GMT+8, 2026-11-6 04:54 , Processed in 0.463753 second(s), 36 queries , Gzip On.
