查看: 859|回复: 4
[求助] [求助]:请帮忙看下这个程序
发表于 2006-5-18 20:06:42 | 显示全部楼层 |阅读模式
我运行下边这个程序时提出这样的错误:; 错误: 参数类型错误: consp nil
(setq n1 0)
(setq f_handle (open "filename.txt" "w"))
(write-line "jfdiajfdskl" f_handle)
(while (< n1 (length lista))
;(setq data (nth n1 lista))
(write-line (strcat (rtos (car (nth n1 lista))) "," (rtos (cadr (nth n1 lista)))) f_handle)
(write-line (strcat (rtos (car (nth n1 listin))) "," (rtos (cadr (nth n1 listin)))) f_handle)
(setq n1 (+ n1 1))
(close f_handle)
而这样时则是正确的
(setq n1 0)
;(write-line (strcat (rtos (car (nth n1 listin))) "," (rtos (cadr (nth n1 listin)))) f_handle)
(setq n1 (+ n1 1))
(close f_handle)
是不是不能连着使用write-line这个命令阿
发表于 2006-5-18 20:13:43 | 显示全部楼层
当然不是了,
根据"错误: 参数类型错误: consp nil"猜测,你的某个变量为nil时作为参数传递给其它函数了.
 楼主| 发表于 2006-5-18 20:17:03 | 显示全部楼层
谢谢
根据你说的,我找到错误了
还想请教一个问题,就是write-line命令之后能不能不换行?
在同一行输出另一个write-line即:下边这两个write-line在同一行显示?
谢谢
发表于 2006-5-18 20:32:02 | 显示全部楼层
(write-line
  f_handle
 楼主| 发表于 2006-5-18 20:54:43 | 显示全部楼层 |阅读模式
这么简单啊!我怎么没有想到啊
赫赫成功了,谢谢
GMT+8, 2026-11-3 10:18 , Processed in 0.535783 second(s), 42 queries , Gzip On.
