查看: 1692|回复: 7
[LISP函数]:如何在VLISP下建立选择集?
发表于 2006-5-24 18:47:04 | 显示全部楼层 |阅读模式
如 AcdbText,AcdbLine.....
发表于 2006-5-26 11:25:25 | 显示全部楼层
lisp好像不行。
 楼主| 发表于 2006-5-26 15:04:29 | 显示全部楼层
看来最近高手都比较忙?
发表于 2006-5-27 13:45:18 | 显示全部楼层
什么意思,建立包含AcdbText的选择集?
再说的具体些
发表于 2006-5-27 14:17:31 | 显示全部楼层
(ssget '((0 . "TEXT,LINE")))
发表于 2006-5-27 16:00:51 | 显示全部楼层
发表于 2006-5-28 17:01:56 | 显示全部楼层
AUTOLISP 好像可以的
 楼主| 发表于 2006-5-29 18:39:26 | 显示全部楼层
To select ALL the Circles on Layer "2", We would write this :
;create a 2 element array for the DXF Code
(setq filter_code (vlax-make-safearray vlax-vbinteger '(0 . 1)))
;create a 2 element array for the values
(setq filter_value (vlax-make-safearray vlax-vbvariant '(0 . 1)))
;DXF Code for Objects and Layer
(vlax-safearray-fill filter_code '(0 8))
;the filter values
(vlax-safearray-fill filter_value '("CIRCLE" "2"))
;select ALL Circles on Layer 2
(vla-select newsset acSelectionSetAll nil nil filter_code filter_value)
This is the equivalent in AutoLisp :
(setq newsset (ssget "x" '((0 . "CIRCLE") (8 . "2"))))
GMT+8, 2026-11-22 09:13 , Processed in 0.294624 second(s), 24 queries , Gzip On, File On.
