查看: 1746|回复: 10
[编程申请]:将选中的LINE直线两端各缩短150mm
发表于 2006-5-25 09:25:05 | 显示全部楼层 |阅读模式
求LSP程序,将选中的LINE直线两端各缩短150mm(希望能同时框选多条直线)。谢谢
已领礼包: 111个
发表于 2006-5-25 12:41:05 | 显示全部楼层
请试用以下程序:
  1. (Defun c:test()
  2.    (setq dd (getdist "\n缩短距离(以毫米为单位)<150mm>:")
  3.          p1 (getpoint "\n左上角点:")
  4.          p2 (getcorner p1 "\n右下角点:")
  5.    )
  6.    (if (= dd nil)(setq dd 150.0))
  7.    (if (setq ssa (ssget "w" p1 p2 '((0 . "LINE"))))
  8.        (progn
  9.           (setq i 0)
  10.           (repeat (sslength ssa)
  11.              (setq dxf (entget (ssname ssa i))
  12.                    p10 (cdr (assoc 10 dxf))
  13.                    p11 (cdr (assoc 11 dxf))
  14.                    ang (angle p10 p11)
  15.                    pt1 (polar p10 ang (/ dd 1000.0))
  16.                    pt2 (polar p11 (+ ang pi) (/ dd 1000.0))
  17.                    dxf (subst (cons 10 pt1) (assoc 10 dxf) dxf)
  18.                    dxf (subst (cons 11 pt2) (assoc 11 dxf) dxf)
  19.                    i   (1+ i)
  20.              )
  21.              (entmod dxf)
  22.           )
  23.         )
  24.    )
  25.    (princ)
  26.
  27. )
 楼主| 发表于 2006-5-25 13:06:06 | 显示全部楼层
经cad2004测试,yshf大侠的LSP程序可用。
发表于 2006-5-25 15:04:48 | 显示全部楼层
[php]
;; spline仅支持缩短,ellipse和arc当延伸长度超过周期,不改变。
(Defun c:lenx(/ dd i ss a b)
   (princ "\n 双向延伸曲线长度(支持*line,arc,ellipse)----by 雨箭风刀.2006.5")
   (if (not *lenx)(setq *lenx 0.0))
   (princ "\n双向延伸距离(负值缩短)<")(princ *lenx)
   (setq dd (getdist ">:"))
   (if dd (setq *lenx dd))
   (if (setq i -1 ss (ssget '((0 . "*LINE,ELLIPSE,ARC"))))
       (while (setq e (ssname ss (setq i (1+ i))))
         (setq a (vlax-curve-getstartpoint e)
               b (vlax-curve-getendpoint e))
         (command ".lengthen" "de" *lenx (list e a)(list e b)"")
   (princ)
[/php]
发表于 2006-5-25 21:50:14 | 显示全部楼层
2楼:
(/ dd 1000.0)
没有道理也没有必要!
  1. [FONT=courier new](defun c:test ()
  2.   (CMDLA0)
  3.   (if (null dist)
  4.     (setq dist 150.0)
  5.   )
  6.   (setq        DIST (UDIST 1 "" "\n输入两端要缩短的距离<或直接量取>" DIST nil)
  7.         ss   (ssget '((0 . "LINE")))
  8.         i    -1
  9.   )
  10.   (while (setq s1 (ssname ss (setq i (1+ i))))
  11.     (if        (> (xyp-get-CurveLength s1) (* DIST 2.0))
  12.       (progn
  13.         (setq p0  (xyp-get-dxf 10 s1)
  14.               p1  (xyp-get-dxf 11 s1)
  15.               ang (angle p0 p1)
  16.         )
  17.         (xyp-SUBUPD s1 10 (polar p0 ang dist))
  18.         (xyp-SUBUPD s1 11 (polar p1 ang (* dist -1.0)))
  19.       )
  20.     )
  21.   )
  22.   (CMDLA1)
  23. )[/FONT]
已领礼包: 111个
发表于 2006-5-26 07:51:14 | 显示全部楼层
请问xyp1964:以米为单位绘图,现在输入的是毫米,该如何处理?
发表于 2006-5-26 09:53:31 | 显示全部楼层
支持看来要好学下lisp编程
 楼主| 发表于 2006-5-28 08:34:45 | 显示全部楼层
经cad2004测试,雨箭风刀的LSP程序可用。 谢谢。
经cad2004测试,xyp1964 斑竹的LSP程序可用。 谢谢。
发表于 2006-5-28 09:38:33 | 显示全部楼层
最初由 yshf 发布
[B]请问xyp1964:以米为单位绘图,现在输入的是毫米,该如何处理? [/B]
当“以米为单位绘图,现在输入的是毫米”时,确实要(/ dd 1000.0),不过帖子的主题没有这个限定,有了这个限定反而受约束。
问题:
当线长小于2×150时,线没有缩短反而加长了。
发表于 2006-6-3 16:09:49 | 显示全部楼层
都可以用啊
发表于 2013-6-9 17:26:24 | 显示全部楼层
我已经有LE~~~~~~~
GMT+8, 2026-11-2 17:00 , Processed in 0.709734 second(s), 52 queries , Gzip On.
