查看: 1362|回复: 0
[求助] [求助]:高手帮忙看看下面代码哪写错了!提示语义错误
发表于 2006-5-26 22:35:41 | 显示全部楼层 |阅读模式
//dcl_zhouwdraw.dcl
dcl_zhouwdraw: dialog {
   label = "绘制圆弧轴网";
   : row {
      : column {
          :Image2 { key="ImagePreview"; width=44; }
      :column {
         :radio_row {
                  key="NetDirection";
                  spacer;
                  spacer;
                  :radio_button { key="KJ"; label="开间(角度)"; value="1";}
                  :radio_button { key="JS"; label="进深(尺寸)";}
                  spacer;
      NetSize;
      SumSize;
    : row {
       : boxed_column {
           label="起始参数";
           : row {
              :button { label="起始角度"; key="PickAngle"; width=10; fixed_width=true;}
              :edit_box { key="StartAngle";  edit_width=6; fixed_width=true;}
          // : row {
              :button {  label="起始半径"; key="PickRadius"; width=10; fixed_width=true;}
              :edit_box { key="StartRadius"; edit_width=6; fixed_width=true; }
           :button{label="切换插入基点";key="Basic_Point";}
           :boxed_radio_column {
              label = "旋转方向:";
              key = "ArcDirection";
              :radio_button { key="AntiClock"; label="逆时针"; value="1";}
              :radio_button { key="ClockWise"; label="顺时针"; }
           : boxed_column {
             label="共用轴线";
             : toggle { key="DrawStart"; label="绘起边"; value="1";}
             : toggle { key="DrawEnd"; label="绘终边"; value="1";}
    EnterANDCmd;
   errtile;
GMT+8, 2026-11-23 21:50 , Processed in 0.213741 second(s), 10 queries , Gzip On, File On.
